1/8 or 3/16ths
1/8 or 3/16ths
Postby Keith B » Tue Jan 30, 2007 5:07 pm
I know everyone here likes the Harbor Freight trailers, but I'm going 5x10, so I'll weld up my own. Harbor Freight trailers are 1/8" angle...for those who build there own, are you going with square tubing and are you using 1/8th or 3/16ths. I know 2x1/8" round would be quite strong, but on square you better be dead on where you put the shackle, axles and shocks or you may kink it on a hard bump, drag, etc... any thoughts?
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby mikeschn » Tue Jan 30, 2007 5:52 pm
I used 2x2x1/8" square tubing for the chassis and 2x2x3/16 for the tongue.
My next chassis will be very similar.
P.S. I use torsion axles for the simplicity and the built in damping.
Images: 479
Postby Leon » Tue Jan 30, 2007 6:01 pm
mikeschn wrote:I used 2x2x1/8" square tubing for the chassis and 2x2x3/16 for the tongue.
Same here, works great.
Leon
Images: 21
Postby madjack » Tue Jan 30, 2007 6:02 pm
...did the same!!!................ 8)
Postby Juneaudave » Tue Jan 30, 2007 7:12 pm
Keith...don't froget to read the Frame Tutorial!!! A couple of our members did a really nice job putting it together.
Frame Tutorial
Juneaudave
Images: 380
Postby asianflava » Tue Jan 30, 2007 8:27 pm
I used 2x2x1/8 for everything, including the tongue. I'm not too happy with the tongue and actually shortened it. It was fine but I thought I'd get a little extra strength by chopping off 20in. I should gone with 3x3x1/8 or 2x2x3/16 for the tongue.
A good place for info is here:
http://www.angib.pwp.blueyonder.co.uk/t ... tear84.htm
I found couplers for 3in tube all over th place. I had to look for a coupler for 2in tubing.
asianflava
Postby Keith B » Tue Jan 30, 2007 10:15 pm
There's safety in numbers... you all went w/ 2x2x1/8th and 3/16 on the tounge, so point taken and I'll do the same. Thanks for the tips fellas.
Keith
Keith B
Postby bledsoe3 » Wed Jan 31, 2007 2:34 am
I used 2X2X1/8 for the frame and 2X3X3/16 for the tongue. Probably overkill on the tongue.
http://tnttt.com/album_ ... ic_id=1991
bledsoe3
Images: 112
Frame weight?
Postby RichAFix » Tue Feb 20, 2007 11:21 pm
Do any of you 2"x2"x.125" framers know the weight of your frame with axles/tires? I am looking to custom build my own frame also, but weight is a concern. My frame will be 5'x'10. I want this to be strong, but the more I think about this I may want to tow it with a Dodge Caliber (1000# tow/150# tongue capacity). I have a truck, but it would be nice if the car could tow this also.
Listen to what I'm thinking, not what I'm saying.
RichAFix
Images: 10
Postby Dean in Eureka, CA » Tue Feb 20, 2007 11:35 pm
Rocky,
You could add a strap truss under the tounge and gain a lot of strength...
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby doug hodder » Tue Feb 20, 2007 11:54 pm
Keith...I don't know what your welding capabilities are, but check out some of Andrews materials/ strengths and weights in the design library, .120 and .090 2x square tube is readily available as well as 16 gauge which is what I welded up the last one with. Look around at what some of the manufactured trailers are using for tongues...my opinion...3/16, in a 2x3 profile is pretty beefy...could easily use a lighter gauge without sacrificing any strength, based on what you are building...and when it is all said and done...it's just that much more weight you are pulling, and having to stop. The body is going to provide a lot of strength, not like a piece of equipment riding on it and relying on the frame...you might want to drop Andrew (resident engineer) a PM for his thoughts...just an idea Doug
RichAFix...the frame as shown in the tutorial weighed in at 290# complete, 4'6" x 10 with a 4' tongue, rear jacks, tongue wheel, tires/wheels the works, and it has 15's on it.
Postby asianflava » Wed Feb 21, 2007 3:27 am
Dean in Eureka, CA wrote:Rocky,
Yeah, that was my second worst case solution, cutting the welds and replacing it with 3X3X1/8 was #1. Since my buddy did it for free, I would feel bad having him do more work. Cutting down the length was easier. If I encounter any more flexing, I'll just replace the whole tongue. That way, I can add a tongue box.
asianflava
Postby TRAIL-OF-TEARS » Wed Feb 21, 2007 5:39 pm
Keith,
there are a few of us that have built our frames with angle I used 2x2x1/4" and a torsion axle, built similar to Camp-Inns frame, only they use 1/8". I can pick my frame up by my self with out wheels/tires. Has about 10,000 miles on her and still holding together.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
