In trying to figure out how to overhang my TTT floor past the 4' width of the trailer, I know of two possibilties: Build wheel wells or build up my floor above the tire.
For option 2, I am trying to figure out how high I need to make the floor above the tires to make sure it never hits.
Since this is the 12" 1740# HF trailer, the tire top sits about 1.5" above the top of the frame...so I can't just go straight across flat like Steve did with his Puffin. If I use a 2x4 to frame the floor, I would clear the tire with my decking by about 2". However, that is without any spring compression. I measured 1.5" from the frame rail to the top edge of the u-bolt threads that are holding the axle to the spring. So i guess the maximum travel of the springs is 1.5" (which seems short, but I believe I correctly assembled the trailer). Then the question is, is 1/2" enough leeway "just in case" or should I build the floor with 2x6" or 2x4"s with 1x2 furring strips on top?
I plan to use a Forstner bit to create pockets on the bottom of the framing for the trailer bolts. And I'll attach the framing by bolting through the 2x in to the trailer frame and countersinking those bolts.
I haven't discounted the wheel well idea...especially since they would be hidden by cabinets on both sides anyway. But 2x framing does make it easier to frame my dropped floors.
A couple of pics...I just used scrap x4 and x6 material with a thin strip to represent the floor. It shows the clearances (no spring compression).
Thoughts?
Matt
