by brian_bp » Mon Aug 27, 2007 6:00 pm
In Europe brakes are required, but I don't think they need to be surge type... maybe a European member can supply the correct info.
The only problem I know of with hydraulic surge disk brakes is that the master cylinders in the surge couplers are too large in bore, so they don't produce enough pressure for light trailers... they're not available in a range of sizes, and the ones you can get are sized for bigger stuff. This is a hardware availability issue, not a basic design fault.
I think the sizing issue is probably the source of the contention that they don't work well for light trailers. In Europe, cable-actuated surge brakes are used on quite light trailers.
Surge brakes inherently adjust to trailer load, but the ratio of master cylinder to slave cylinder sizes must be designed correctly from the beginning. Electric is easier for random design followed by tune-to-work, surge systems suit a properly designed vehicle. My guess is that examples given (in the other topic) of problems with heavier surge-braked trailers may be similar detail design issues.
A CR-V towing a 1500 lb trailer without brakes is certainly overloaded. Essentially all passenger vehicles and trucks under "full size pickup" call for trailer brakes for any trailer over 1000 lb.
The idea of surge brakes not working while backing seems ridiculous to me. As I read the Euro requirements, free-backing brakes are required, since any manual lockout scheme risks the user forgetting to re-activate them before resuming travel.
If the brakes are applying themselves going down a hill, the tug must be holding the trailer back, which means that perhaps they should be applying. One of the few problems of the advanced acceleration-proportional electric controllers is that they don't do any braking on a steady speed descent, even if the tug is braking. On the other hand, the potential overheating issue seems like a good point to me... and I don't have the ideal solution. Certainly, the manual lever on an electric controller is not it.
If you ever need to manually hit the trailer brakes due to a sway problem, I think you need to fix your trailer, not the brakes.
