Dale M. wrote:Why...... They tend to push grease out rear seal and it splatters all over inside wheel and fender...
Dale
packerz4 wrote:Dale M. wrote:Why...... They tend to push grease out rear seal and it splatters all over inside wheel and fender...
Dale
yep, and my HF utility trailer has that problem... how do i fix it. i know to take the bearing buddies off, remove castle nut, but then what? how do i fix that rear seal, and where do i get it from? i've read past posts about the seal being an odd size. does Harbor Freight carry the back seal?
thanks in adavance! any info you can send me will help. or pm me if you wanna...
tk
Save yourself the aggrivation take the old seal to a good automotive parts store and let them cross reference it. If you have a bearing specialist industrial supply store even better. While your there take the inner and outer bearing with you and get a spare set. In case of failure in route Taking 20 minutes to change them on the road beats the alternatives.packerz4 wrote:Dale M. wrote:Why......
Dale
... how do i fix that rear seal, REPLACE IT and where do i get it from?
tk
