Several years ago I bought this frame at auction really cheap.
Since then I have used it for many uses including a flat bed utility trailer and its current configuration as a ladder rack.
It measures 4' wide at the frame rails and just over 8' long from the rear edge to the front cross rail. it has extensions on both side of aprox. 9" on each side.
It has a drop axle and electric brakes (I have never used them so I am sure they would require some repairs if not a complete rebuild).
I am not sure what style of TD i am going to build yet, but do know I want 54' width minimum so I can use a full side inflatable mattress (not as thin as I used to be, needs to sleep myself and wife).
So the big questions are:
From the pics does it look like it is a good start or should I start over?
I plan to tow with my full size pick up or mommas Yukon, so are brakes even needed?
If I do use this trailer, are there any modifications I should make?
