by bobhenry » Tue Oct 30, 2007 7:57 am
I custom build mini barns and move them on a 8' x 24' flat bead trailer.
To load them I simply use two handy jacks to raise one end and drive the trailer under the barn I then use some schedule 80 pvc for rollers. Jack the other end and winch it on the trailer. You can raise the building with a pry bar and remove the rollers after its loaded. There is no reason a pod could not be built as a tear , another as a state bed , another as a flat bed , and yet another as a box trailer. Four trailer types with the expense of 1 trailer. I think 2 sections of conveyor would be the ultimate answer to loading and unloading the small pods.
