Frame questions
Frame questions
Postby Ropes4u » Fri Apr 11, 2014 6:25 am
So I have recruited a welder and picked a design, we decided to build a Li'l Bear
Now I want to stretch it to a 5x8 frame which after talking to Grant I feel like we have a good plan for the frame and tongue.
The trailer will be a 1/2" plywood foam sandwich with an aluminum skin. Build as simple and as light as I can with basic tools. We are buying a 2200# axle with e brakes installed.
Any huge blunders?
Ropes4u
Re: Frame questions
Postby Esteban » Mon Apr 14, 2014 12:11 pm
It seems to me that you need to provide considerably more information to folks here about your design and plans to get well informed feedback. :thinking:
Steve - SLO, CA
Esteban
Images: 15
Re: Frame questions
Postby KCStudly » Mon Apr 14, 2014 11:43 pm
Is that 1/2 ply inside and out with foam in the middle?
You can go thinner on the inside for sure, and the outside, too, for that matter.
Re: Frame questions
Postby Ropes4u » Fri Apr 18, 2014 10:47 pm
Maybe I should post a drawing, but it is going to be a simple modernistic / cub design. 3/8 Baltic birch plywood with 1/4 - 1/8 skin and 3/8 center will probably be the ticket.
Ropes4u
Re: Frame questions
Postby AaronRCTID » Mon Sep 28, 2015 7:33 pm
Sounds like your design is fairly similar to mine. How's it coming?
AaronRCTID
Re: Frame questions
Postby tony.latham » Mon Sep 28, 2015 9:27 pm
Any huge blunders?
Blunder? To begin with, listening to Grant is an anti-blunder. (I can't Google-up an antonym for the word blunder BTW) The guy is the Dalai Lama of teardrop building. I'm being serious here. I would have told you that a sandwiched wall with the "guts," or "bones," made from 3/8" plywood is too thin. Heck, I prefer 3/4". But if Grant suggests it, by all means go for it.
The guy has made more quality teardrops than I'll ever see. :thumbsup:
I assume you've seen his last build he documented on Facebook? https://www.facebook.com/teardrops.net?fref=ts
