Foam Standie Frame
Foam Standie Frame
Postby donrebyct » Tue Sep 30, 2014 6:26 pm
Just wondering if a Harbor Freight trailer would be hefty enough to build a foam standie, roughly 6.5' wide by 10' long. I've heard they are a bit light weight, but my foam camper should be fairly light weight, too. Any opinions?
Don
donrebyct
Re: Foam Standie Frame
Postby KCStudly » Wed Oct 01, 2014 7:10 am
Some regions and conditions are going to be more sensitive regardless of the type of construction.
Wheels under on a 5 wide trailer should work fine provided you don't build super tall. IMO, even using traditional construction, on a 4 wide you would be pushing things with regard to stability. Sure, some folks will tell you that they have done it and never had a problem, but you have to factor in the conditions that you intend for; their situation may differ.
More information is always useful. What features do you plan on adding; recessed floor, under floor battery and/or water tanks, cast iron cookware, 500 gal of beer, fridge, A/C, etc.? All of these things could help mitigate a top heavy situation if configured carefully.
Resist the urge to "build a house" on wheels (think airplane not tank), then ballast and/or act accordingly if and when required.
If the weather calls for severe winds with trailer warnings, hunker down. Anchor it like an airplane using tent stakes, sand anchors or other fixed objects to tie off to, park near a wind break... a building, bluff, down in a protected valley, etc... angle into the wind, and/or ballast up.
In less severe conditions where caution is still advisable while traveling, every Walliemart, Ho-De-Po, supermarket, etc. has cases of bottled water for something in the range of $3 a 30 pack. A twenty dollar bill will get you over 200 lbs of consumable/configurable ballast that can be placed low on the floor in mass, or individually anyway you can tuck them. To lighten the load later just use the water (don't forget to recycle the bottles!).
I would rather build lighter for the 99/ct of the time that the wind is not a big deal, and act accordingly during the 1/ct of the time that it is an issue; rather than haul around all of the excess "I built too heavy" weight 100/ct of the time.
Postby tac422 » Wed Oct 01, 2014 7:23 am
The Big Pink (foamie) is a recessed floor standie built on a Harbor Freight trailer. It is 10' 3" x 5' 7".
It weighs 900 lbs loaded with with niceities like a fridge, AC, potty, toaster oven,coffee maker,popcorn machine, popup tent etc.
123715
tac422
Postby donrebyct » Wed Oct 01, 2014 1:51 pm
Thank you for the replies. Adding ballast for windy conditions is a very good idea.
TAC22, the Big Pink is very close to what I'm thinking about. I need to look any postings you have on it. The only thing I would add would be some sort of shower capability and a small fresh water tank, and possibly a hot water heater (if room). If my wife will agree, maybe I could use a hand pump sprayer for the shower.
I really like the Retro 155 built by Riverside RV. What I don't like is the cost ($12K if I go to Allentown, PA or $14K close by) and the weight (1840 lb to 2040 lb). And the tonged weight is 300 lb. I'm sure my Grand Caravan can handle the weight, but I don't want to push it too much. And the pocketbook can't handle the cost right now.
I'm hoping to have something by next summer for a long delayed Alaska trip.
Don
donrebyct
