Krusty wrote:I'm looking around now for some slightly larger radial tires to go on my harbor freight trailer. Anyone have some good sources for 4 bolt pattern wheels that'll hold a 13"-14" radial tire? I actually wouldn't mind finding some car wheels instead of trailer wheels (with the lug mounting surface further out to the side) as I upgraded the axle and put some brakes on it since I'm towing with such a small car.
bobhenry wrote:Krusty wrote:I'm looking around now for some slightly larger radial tires to go on my harbor freight trailer. Anyone have some good sources for 4 bolt pattern wheels that'll hold a 13"-14" radial tire? I actually wouldn't mind finding some car wheels instead of trailer wheels (with the lug mounting surface further out to the side) as I upgraded the axle and put some brakes on it since I'm towing with such a small car.
I forgot to add you can simply change out the hub for a 5 on 4 1/2 bolt pattern they are about $25.00 each and come with the bearings. Now the sky is the limit on options.
eggsalad wrote:etrailer.com has 13" 4x4" wheels for $25.
http://www.etrailer.com/Tires-and-Wheels/Americana/AM20222.html
http://www.etrailer.com/Merchant2/graph ... 2_1000.jpg
You won't find much bigger than 13" in 4x4"
