KCStudly wrote:They can be slightly forward, neutral or slightly rearward at rest with different handling characteristics. I prefer them to be slightly pitched forward at rest with the load on.
As the spring takes on load it tends to flatten and with the shackle slightly forward to start the weight and compression aren't resisted by the shackle, so the ride is effectively softer. Also, the shackle is less likely to invert.
With the shackle tilted back slightly, as the spring compresses and tries to flatten out and the shackle starts to swing thru its arc it has to first lift the trailer opposing the added load and compression, which tends to stiffen the ride.
The picture you show is on jack stands with the axle drooped out. What does it look like when it's sitting on its own weight loaded? And are you sure that it is the spring eye whacking the frame, or could it be the axle or U-bolts instead? My thinking is that if the shackle geometry is okay, then you are probably under sprung (i.e. under rated on your springs). What are they rated for and how much does your camper weigh when loaded up?
Bump stops are a possible solution to solve any big hits, but this will also reduce available travel, and if you are frequently having hard contact the solution lies elsewhere. If everything checks out and you can allow for a slightly higher ride height, longer shackles might be enough of a difference to solve the problem.
