sunny16 wrote:When I built my frame I tried to use my Delta wood chop saw with the appropriate blade for metal but it lasted about three cuts, the blade that is.
Why only 3 cuts? What happened to the blade? Did it go dull, or break? I'd like to try the miter saw at least for the 45 degree cuts. I have the 4 1/2" HF grinder as a backup plan.
angib wrote:Chop saws are lovely, if noisy. But you can't beat the 4.5" angle grinder for cheapness and versatility - you need one in addition to a chop saw for that detail work. Then put a sanding cup and disc on it and you get a truly versatile woodworking tool - known in boatyards here as the 'electric spokeshave'.
Andrew
Joanne wrote:A guy at work kept telling me to get one but I was skeptical. Finally I scraped together a few bucks and bought a Makita.
