Angle Iron livestock vs C channel enclosed, holding tanks.
Postby rebar » Tue Mar 26, 2019 5:51 pm
Ive been shopping for a trailer and talking to K&O in Hull Iowa. They'll build me the narrow track axle option I want, but I just noticed the majority of the trailer is built from angle iron. I imagine this is common and helps keep a livestock floor low. But the cargo trailers and campers Ive considered have space in the frame for tanks and utilities because they use C channel.
This K&O pace setter is built like a tank with 20 gauge skin, 7k straight axles etc, but I'm not envisioning allot of clearance/protection for holding tanks. Or maybe my problem is the tanks will be more visible and exposed. And I don't need 2x10's, but 3/4 plywood floor, which is just to exposed and low again.
I'm thinking converting it will be more challenging, because I will have to build a raised floor 6" over the existing, but the ramp door would have to be raised the same amount..
Considering I want allot of water under my trailer, is a livestock trailer a bad idea because its so low?
Thanks!
97 12 valve 4x4 5 speed
rebar
Re: Angle Iron livestock vs C channel enclosed, holding tank
Postby Az Pete » Tue Mar 26, 2019 6:06 pm
do you need a ramp door?
It would be easier to understand if you posted a sketch of the finished trailer, or described what the end product is to accomplish.
I like the idea of a raised floor, it could give you a lot of storage, in addition to space for your tanks and make it easy to wire.
Az Pete
Postby rebar » Tue Mar 26, 2019 7:41 pm
A ramp door is a must have and end product is a toyhauler designed to handle forest service roads and the yukon highway. The raised floor does sound useful but time consuming and additional expense.
K&O said they could use straight axles which is a 3" lift.
I have another builder who will build me a traditional cargo trailer. But its more expensive with thinner skin.
rebar
Postby Az Pete » Tue Mar 26, 2019 8:07 pm
That is a nice looking trailer.
Hope you don't give up on the sturdier trailer. Having over 30 years work experience driving FS roads, I can vouch for "sturdier is better". We had horse trailers that were over 20 years old, and I am not sure a cargo trailer would have lasted that long. A travel trailer surely would not have.
Can you raise the floor, but have the rear most part taper down to the door hinge? Would probably have to be at a steeper angle than the ramp, but manageable, I think.
Or conventional doors with ramps? Just hang the ramps on the doors for travel.
Az Pete
Postby rebar » Wed Mar 27, 2019 7:25 am
Az Pete wrote:That is a nice looking trailer.
I thought about tapering the floor to nothing in the rear to match door height.. But If I'm paying to have a custom trailer built, it will be how I need it, or nothing at all.
Here is a "narrow track" enclosed trailer.. I offered $4k with no response.. In fact I offered that last year when they had it on craigslist..
https://madison.craigslist.org/tro/d/madison-enclosed-trailer-7-18-carson/6837495212.html
rebar
