Worth $400 as donor frame?
Postby Margali » Sun Apr 07, 2019 7:27 am
I have lead on 1994 Palimino TXL- FG hardside pop-up that has broken roof for $400. Was thinking about using it for donor frame and selling AC, stove, etc. The frame is really rusty looking though.https://drive.google.com/file/d/1apWybuK8giEbK7_6FbltwzCmybKV9wds/view?usp=drivesdk
Good or bad deal?
Margali, DH, and 3 minions
2017 Ram 1500 Lonestar, 7'x 16'x 7'h v-nose
Margali
Images: 14
Re: Worth $400 as donor frame?
Postby rmclarke » Sun Apr 07, 2019 9:00 pm
Depends....is it just surface rust? If so, not a huge problem. I recently picked up a 1984 Starcraft tent trailer for $150; just had surface rust... a gallon of Corroseal @ Amazon is about $50.
You have to make sure there is no loose scaly rust. I wire brushed the frame, washed and dried it, then wiped it down with denatured alcohol before applying 2 coats of Corroseal......after the Corroseal was well dried, I applied a coat of primer and a couple top coats of Rustoleum gloss black.
Before:
After:
rmclarke
Images: 225
Postby les45 » Mon Apr 08, 2019 3:54 am
I did the same as rmclarke with my 89 Jayco. My main concern was the welds around the A-frame but they looked good after wire brushing and inspecting. I wire brushed all the loose rust and then coated everything with Corroseal and topped off with Rustoleum.
les45
Images: 596
Postby Pmullen503 » Mon Apr 08, 2019 6:25 am
What's your time worth and will your build fit the trailer without too much modification?
Pmullen503
Images: 58
Postby swoody126 » Mon Apr 08, 2019 7:06 am
rmclarke wrote:Depends....is it just surface rust? If so, not a huge problem. I recently picked up a 1984 Starcraft tent trailer for $150; just had surface rust... a gallon of Corroseal @ Amazon is about $50.
Before:
After:
if the frame size n shape meets your needs this would be a good way to go
sw
swoody126
