Buying a used trailer from Facebook?? Help?
Postby siena » Thu Dec 19, 2019 12:12 am
Hi all, I was originally going to get a 4 x 8 from HF, but I decided I really wanted that extra foot for 2 people and a dog camping, so I am looking for used 5 x 8 trailers on facebook marketplace and craigslist. I am going to attach pictures of some of them. I really do not know what to look for in a used trailer other than weight of trailer and weight rating. Weight of trailer is important because our towing capacity is only 2200 lbs. How important is the front triangle around tongue? Does it significantly reinforce it? Please consider helping me choose.
I have 4 options
1. The old military 6 x 8
Pros-looks like it is rated to 2700 lbs ish, Plus side of having an extra foot width.
Cons- looks like the trailer's heavy
2. The cheap 5 x 8 with wood sides I'd have to take off
Pros- it's cheap, rated to 1500 lbs, registered w paperwork
Cons- not sure about tongue strength, rated to 1500 lbs
3. The green one
Pros- tongue looks good, rated to 4500 lbs which is double what I need
Cons - more than I'd like to pay @$750 obo
4. The Vermont 5 x 8
Pros- rated at 2000 lbs then beefed up with super duty tongue, $600 obo so more in my price range
Cons- no front tongue triangle for tongue box, have to drive a few hours to get it
Sent from my SM-G973U using Tapatalk
siena
Re: Buying a used trailer from Facebook?? Help?
Postby siena » Thu Dec 19, 2019 12:15 am
Sorry here are better resolution pics of the last 2 Image
siena
Postby RJ Howell » Thu Dec 19, 2019 7:33 am
All the trailers do not look equal in condition. Condition is number one in my mind. I also tend to look for a trailer that is rated 150% over my intended loaded weight, it's amazing the amount of force a simple pothole on the highway causes. Tongue's IMHO are Single straight as least, V as good, Hybrid Combination of both best. In any case tongue should run under the trailer box frame, not just welded to front cross member. You can always add supports to a straight for a cargo box.
RJ Howell
Images: 36
Postby Redneck Packrat » Thu Dec 19, 2019 8:29 am
The one you're calling #2 jumps out at me, for several reasons. First is something I'd have to verify in person, and that's that it's as solidly maintained as it looks. From the seller's pics (which, ya gotta remember, almost always are of the object's best features ;) ) I don't see any glaring flaws.
I do like that it appears to be a 5x8 bed with the wheels tracking outside the bed. Yeah you'll have to design around fenders but that's not so bad either, it does give you the option of going to six by eight with five of it flat floor.
I do like that it appears to have decent wood, not rotten or beat up, implying that at least a hint of care was shown to the thing's upkeep. The fact that it's unpainted is immaterial. Paint sometimes is its own worst enemy in that it traps/hides problems. (Green one could be a flaky mess held together with the paint :shock: )
Take a jack with you if you have more than 10-15 miles to get it home and pick up each side and roll the tire. Push it in and out while you're turning it. Should roll smoothly. If it's sloppy but smooth rotating, probably be fine to take home to do the maintenance on it. Additionally, it'll be a GOOD indication of how much use or how little maintenance it's gotten. While you're down there, take your handy little pocket tape measure and measure the wheel lug bolt pattern. Looks like it'd be 4.5" but can't see if there's 4 or 5 lugs. Either one is readily available as a tire/wheel assembly from most anywhere like Walmart, Tractor Supply, HF etc. What I'm saying is really, so long as it's not an oddball metric of some sort it's not a cause for concern since they're (the wheels and tires) all over-built for a lightweight trailer.
The price is a big plus. I don't know about your state, but here, $300 is just about a minimum to break even buying .vs. building yourself from scratch with found materials and getting lights and plates on it. Basically, all used trailers are 300.00 trailers with varying amounts of extras.
All said, at least do go look at that #2 you listed, and when you do check the coupler, tongue, suspension and axle for leprosy. Not sure how bad rust is where you are, or more to the point where that trailer's been! :lol: Surface rust not so bad, it's on everything ferrous here. Deep pitted candidates for a leper colony, are things to beware of. If the coupler and tongue are free of scary looking rust and the rest doesn't scare you off, show the seller a couple hundred and start from there. It's already established the seller's gonna go down, looking at how he accepted FB auto-adjusting the price over time.
To counter your cons, if you do get this one, you've got a couple hundred dollars to play with as far as A braces for the tongue, sawzall blade or torch gas to remove the sides, things like that.
Bottom line is, it'd have to UN-sell itself in person, to me. Good luck with your hunt!
Bill
Texas Gulf coast, near Corpus
Working on this, started 5/2017: http://www.tnttt.com/viewtopic.php?t=68614
Some days you're the bug, some days you're the windshield :?
Redneck Packrat
Postby greygoos » Thu Dec 19, 2019 1:08 pm
Redneck Packrat wrote:The one you're calling #2 jumps out at me, for several reasons. First is something I'd have to verify in person, and that's that it's as solidly maintained as it looks. From the seller's pics (which, ya gotta remember, almost always are of the object's best features ;) ) I don't see any glaring flaws.
Hey Redneck . Not to get off the subject but nice to see you back. How is the build going?
greygoos
Postby siena » Sat Dec 21, 2019 8:18 pm
All said, at least do go look at that #2 you listed, and when you do check the coupler, tongue, suspension and axle for leprosy. Not sure how bad rust is where you are, or more to the point where that trailer's been! Surface rust not so bad, it's on everything ferrous here. Deep pitted candidates for a leper colony, are things to beware of. If the coupler and tongue are free of scary looking rust and the rest doesn't scare you off, show the seller a couple hundred and start from there. It's already established the seller's gonna go down, looking at how he accepted FB auto-adjusting the price over time.
Hey Redneck! Thanks so much! The guy keeps lowering the price on it too so I'm going to check it out after christmas and see how it goes. I found a friend of a friend up here who works on trailers so hopefully he could weld some things for me.
siena
