Mounting the box
Mounting the box
Postby MickinOz » Fri Apr 30, 2021 7:40 pm
OK - I admit it, my search skills are crap.
How do people mount secure their box to the drawbar?
I could simply sit it on the A-frame and drill TEKs down into the drawbar tubes.
That would be cheap, simple and quick, but I have a few doubts about strength and corrosion.
I could add some tabs on the inside of the A-frame and through-bolt the box.
I am pondering some u-bolts such as are used for securing spare wheel carriers, etc.
What do people do?
Pictures please, folks.
MickinOz
Re: Mounting the box
Postby twisted lines » Fri Apr 30, 2021 8:23 pm
My box rests on the A frame but I welded Angle Iron front and rear of the box and drilled 4 holes through the box & angle;
Won't have un threadable bolt, nuts.
Angle Iron.jpg (39.64 KiB) Viewed 607 times
Racking up; And Rapin foam
twisted lines
Postby Socal Tom » Sat May 01, 2021 7:33 am
My tongue is made of C channel. I drilled through and bolted the box down through it and bolted the box there.
Socal Tom
Users browsing this forum: No registered users and 25 guests
