Tool for removing minor rust on trailer chassis?
Postby TimC » Mon Jul 19, 2021 8:26 pm
Can you recommend a tool for removing surface rust from a trailer chassis? I have an old Ryobi 4" grinder. Would one of those knotted cup brushes be too aggressive? I don't plan on removing all the paint, just the rusty spots. Maybe less than 10% of the area.
I'll use a rust reformer/killer/conditioner type product as a primer then brush on enamel as a finish coat.
Thanks, Tim
Tim
Niagara, WI
TimC
Images: 736
Re: Tool for removing minor rust on trailer chassis?
Postby pchast » Mon Jul 19, 2021 9:20 pm
I've used an abrasive drill driven brush or wheel.
Effective and easier to handle than a wire wheel.
similar to:
https://www.harborfreight.com/2-inch-80 ... rill+brush
pchast
Images: 97
Postby saltydawg » Mon Jul 19, 2021 9:34 pm
If its just surface rust just use one of the converters that make it paintable. You want to knock off any flakey rust first.
Scott
Lost in Maryland
saltydawg
Postby JunkMan » Tue Jul 20, 2021 6:55 am
I've never used the knotted cups, just the regular ones. Use what you have! I like flap discs too, but they will remove metal, where the wire cups will just remove the rust. They are nice for areas that will show since they leave a smooth finish.
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby twisted lines » Tue Jul 20, 2021 7:06 am
Your plan is spot on!
Wire cup with Two hand's and don't be surprised if the little wires are stuck in your clothe's :frightened:
Eye protection for everyone on the block.
May sand a little before primer and paint!
May cause cancer in California.
Racking up; And Rapin foam
twisted lines
Postby TimC » Tue Jul 20, 2021 8:38 am
Thanks guys!
I don't have any type of wire brush for the 4" grinder. That thing screams at about 11k rpm and scares the bejesus out of me for anything but grinding a metal surface or cutting bolts. I can't imagine using a wire cup brush under the trailer upside down on my back.
I have a random orbit sander that is slower but it sounds like it might be too aggressive as well. I'll take a good look at the trailer before buying something else. The last job I did on my teardrop tongue I thought about buying one of those cup brushes for the grinder. But one day I just said the hell with it, I'm going to grab a regular wire brush and see what I can get done. In about fifteen minutes I had the tongue brushed down to bare metal where it needed to be and proceeded to clean and prime. The trailer chassis is a much bigger job, but, I feel that the welds at seams are the areas that most need to be cleaned and I'd have to do that with a hand brush anyway. We'll see how long it takes me to give up on that :lol:
Tim
Niagara, WI
TimC
Images: 736
Postby twisted lines » Tue Jul 20, 2021 9:23 am
HF has a cheap cup brush toss a few buck's for a Test :thumbsup:
The Orbital loves that stuff I like 220 Grit.
twisted lines
Postby TimC » Tue Jul 20, 2021 9:47 am
twisted lines wrote:HF has a cheap cup brush toss a few buck's for a Test :thumbsup:
I might pick up one of those. The one Pete linked to (above) has great reviews. We're not near a HF but could order online.
Tim
Niagara, WI
TimC
Images: 736
Postby Squigie » Tue Jul 20, 2021 1:03 pm
Knotted brush is great until you need to get into the corners.
Then you'll have to go to a smaller tool or do it the old fashioned way, with a brush in hand.
If you want to strip to bare metal, Evapo-Rust Gel might be an option for vertical surfaces.
I'd still hit it with rust converter after the rinse, though.
Squigie
