mnswamp wrote:Scott,
Thank you for a totally contrarian viewpoint. i see it. I hadn't considered going this way, but the additional stiffness and lower weight is spot on. A couple of questions for you.
1. How do you make a smooth transition from the 2x3 to a 2.5^2 weld-on receiver?
2. I am planning on a 5 foot tongue - 24¨ box on the front, + 3 feet in front of that to the ball. I assume the wings should always come in pretty much immediately behind the hitch?
Thanks for the idea.
marsh
including 2 mountain bikes on the back.
Stick to 2x3 .085 if you like for the main inside rails and outside framing, i. e. the bulk of itmnswamp wrote: Timbren strongly recommends .125 as a minimum
Too bad - I had come around to .085.
