Matching wheels
Matching wheels
Postby mixmaster42 » Sat May 28, 2022 8:57 pm
Has anyone thought of using a car or truck hub assembly to build an axle so that they can use matching wheels for their trailer? :thinking:
mixmaster42
Re: Matching wheels
Postby Sparksalot » Sat May 28, 2022 9:14 pm
When I put a new axle in last year I did think about it. I didn’t want to have to get bigger fenders and figure how to remount them.
Sparksalot
Images: 682
Re: Matching wheels
Postby rjgimp » Sun May 29, 2022 1:30 am
It works fine as long as that tow vehicle and trailer stay together.
:vroom:
-Rob
rjgimp
Images: 7
Re: Matching wheels
Postby Captain Monkeyshines » Sun May 29, 2022 2:59 am
Our teardrop has matching wheels and tires to the truck. It works great as long as you like doing 7 tires when it's time to rotate. Also you can get trailer axles with almost any lug pattern to fit your wheels. Ours is 6 bolt Toyota pattern on our Dexter axle
Sent from my SM-G960U1 using Tapatalk
“When You're Alone”
When you're in the kitchen, you've got to behave
You don't put metal in the microwave
The knobs on the stove are “hands off” no doubt
And when you make toast, don't use a knife to fish it out!
When you're alone, when you're alone
You got to stay safe when you're home all alone.
When you're alone, when you're home all alone
You got to make sure not to die, or choke or burn the house down.
Re: Matching wheels
Postby tony.latham » Sun May 29, 2022 9:15 am
Ours is 6 bolt Toyota pattern on our Dexter axle...
Why is it I don't see the end of the hub sticking out from the wheel?
Tony :thinking:
Re: Matching wheels
Postby Captain Monkeyshines » Sun May 29, 2022 12:08 pm
Tony :thinking:
Because that wheel has a 1 inch spacer on it so I can keep my TRD center caps.
“When You're Alone”
Re: Matching wheels
Postby mixmaster42 » Mon May 30, 2022 1:34 pm
I should say where I saw the idea was on a Youtube channel "Dirt Lifestyle". The fellow used a Land rover rear axle with the axle ends cut and bolted back up to hold the unit bearing together. This setup gave him the bolt pattern he needed. Using a unit bearing would be slightly harder at the start but easier to fix on a lite trailer. Non drive unit bearings are crimped to hold together.
mixmaster42
Re: Matching wheels
Postby schnottus » Sat Jun 11, 2022 12:23 am
I went with wheels that match my 4runner when i built mine this winter, 32in tires on 17in rims.
169474
Dexter has all sorts of options, like the 6 on 5.5 pattern hubs seen above. I did have to weld up custom fenders, but i was planning to anyways.
schnottus
Images: 32
