Trailer Frame Input
Trailer Frame Input
Postby Cloyd99 » Thu Oct 19, 2023 3:23 pm
Hello everyone! I am in the early stages of designing and building a teardrop camper and am looking for some information on the trailer frame design. A lot of the links in the stickied threads on the forum now appear to be dead so I am digging for info. Most of the trailer designs I am seeing have the frame on two planes (a square frame above with the tongue attaching underneath). I am more inclined to build a trailer with frame and trailer in a single plane, possibly with a full length tongue. I would think it would be stronger.
Here are a couple rough drawings I did on Microsoft Paint that are more along the lines of what I am thinking. They aren't to scale. Has anyone built a trailer with a similar design? I would appreciate any input I can get.
172653
172654
Cloyd99
Re: Trailer Frame Input
Postby rjgimp » Thu Oct 19, 2023 5:48 pm
I don't have much advice to offer regarding your design but I have discovered many of those old dead links can still be viewed at archive.org also known as the Wayback Machine. 8)
-Rob
rjgimp
Images: 7
Postby twisted lines » Thu Oct 19, 2023 6:03 pm
look good,
Overkill; 1- 1/2 X ?
Use triangles in corner's :thinking: Under
Front joint' ; gusset all the angles instead see above.
Stronger method on rear Joint! more area to weld .
Download (Solid edge) instead of Paint :thumbsup:
Free easy and tutorial's .
Racking up; And Rapin foam
twisted lines
Postby QueticoBill » Thu Oct 19, 2023 6:39 pm
If you put it all in one plane, you have a lot of moment connections. Keeping the "y" and tongue as well as the cross bars unbroken is going to be stronger. Good welding and gusset plates would be almost as strong.
QB
QueticoBill
Images: 22
Postby tony.latham » Thu Oct 19, 2023 6:47 pm
Well... It's considerably stronger if you put the tongue under the frame. It eliminates the tendency to pull the frame apart. There was a Facebook post on one of the Teardrop DIY pages last week that had photos of a trailer with cracks where the tongue butted to the frame and if I recall, it had gussets underneath the corners.
Postby twisted lines » Thu Oct 19, 2023 8:17 pm
A frame under to the second brace with a cap.
My Heavy trailer; outside frame
twisted lines
Postby Cloyd99 » Fri Oct 20, 2023 11:12 am
Thank you everyone for the input!
tony.latham wrote:Well... It's considerably stronger if you put the tongue under the frame. It eliminates the tendency to pull the frame apart. There was a Facebook post on one of the Teardrop DIY pages last week that had photos of a trailer with cracks where the tongue butted to the frame and if I recall, it had gussets underneath the corners.
Tony, I like your frame design. I have been reading through your build thread and will go that way if it's stronger. I am trying to get a better understanding of the forces at work on a trailer chassis. When you say "pull apart" are you meaning the tongue is trying to come out or the entire thing is trying to scissor? Either way, that's scary. Just for fun I mocked up a better model on Sketchup with a full length tongue. Now that I see it drawn though, it's probably overkill and too heavy. I'd be interested in where the weak points would be on this type of design.
172655
twisted lines wrote:A frame under to the second brace with a cap.
What tubing dimensions did you use on your trailer?
Cloyd99
Postby tony.latham » Fri Oct 20, 2023 11:51 am
This design of mine works fine using 2" .120 tubing. You can go 3 x 2" thinner tubing but it's harder to weld. Many-many miles on mine.
With a traditional spring axle, you'd need to add another cross-member with it, and the rear cross-member is fine with 2" .120 angle. Your last sketch looks awful heavy.
Postby halfdome, Danny » Fri Oct 20, 2023 2:00 pm
I've built 6 teardrops with a frame as you speak of.
I have lots of welded gusset's that I mount the high quality plywood floor to with elevator bolts.
As I see it the floor is an integral part of the frame.
The center member is a 48" hitch receiver to accommodate a removable draw bar/tongue.
I weld angle iron pieces on the rear hitch receiver as it's welded below the frame.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby twisted lines » Fri Oct 20, 2023 6:29 pm
The one pictured was free 1/4" wall 2" x 4" Scrap.
Made a hydraulic dump trailer.
twisted lines
Postby swoody126 » Fri Oct 20, 2023 8:53 pm
listen to tony.latham
he's been furthur down these roads than many
utility trailer manufacturers use the under mounted method because they have liability responsibilities and it is stronger
running the framing and tongue on the same plane forces one to cut cross members in 1/2 and butt weld them to your proposed full length tongue
those butt welds aren't as strong as welding 2 pieces one on top of the other ... even with your proposed gussets IMHO
seen too many single plane frame/tongue combinations fail at the point where the frame and tongue meet ... ruins a trip
sw
swoody126
Postby working on it » Sat Oct 21, 2023 10:49 am
I have a single-beam tongue on mine, 72" x 3" square tube, .188 thick. It is attached under the plane of the frame, to three cross-members and a central spine (butt-welded inside the frame). The tongue is sistered to the spine, for extra strength and rigidity.
tongue attached to spine.jpg (359.22 KiB) Viewed 714 times
173193172890148599
working on it
Images: 457
Postby KCStudly » Sun Oct 22, 2023 11:25 am
Other good reasons that OEMs don't do it that way is because it takes more man hours to set all those miters and ensure that the hitch is centered and equidistant to the tips of the axle stubs while still maintaining proper butt weld joints. Much easier to build the A-frame separately and align it before welding it on with a few much easier fillet welds.
Postby QueticoBill » Mon Oct 23, 2023 5:36 am
Either flat - in one plane - or not, can work, but pretty sure the flat approach requires more work and materials, thicker at least, and is likely heavier.
QB
QueticoBill
Images: 22
