Torsion Axels in the Cold
Postby molethai » Sat Mar 18, 2006 4:42 am
Anyone seen any info on the performace of the torsion axels in the bitter cold? Rubber does weird things up here in Jan & Feb.
mole
molethai
Postby angib » Sat Mar 18, 2006 7:59 am
In this page of a photographic tour of the Henschen torsion axle plant, Deep Freeze, it says the rubber used to make the axle is frozen to 200 degrees below zero to hold its compressed shape while being fitted in the axle tube.
So if your frigid north gets down to 200 below, it looks like your axle will lock up solid.....
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby SteveH » Sat Mar 18, 2006 9:12 am
So, Andrew, based on that info, what should we expect at a mere 100 below? :lol: :D :?
SteveH
SteveH
Images: 42
Postby molethai » Sat Mar 18, 2006 10:31 am
Guess that answers my question.
Thanks for the link, very interesting.
Mole
molethai
Postby Chris C » Sat Mar 18, 2006 10:34 am
Leave it to Andrew to always have the answer. :applause: :applause: :applause: :applause:
Mike, I think you need to give Andrew the title of Site Guru!!!!! :thumbsup: He's always there when we need him, and always has the answer.
Chris :D
Chris C
Postby angib » Sat Mar 18, 2006 12:17 pm
SteveH wrote:So, Andrew, based on that info, what should we expect at a mere 100 below?
Truthfully, I don't know - that's why I didn't add any more!!!
The interesting thing is that freezing the rubber to 200 below (I presume that's Fahrenheit, so it's 'only' about 150 Kelvin) doesn't do it any damage - you might think it would become so brittle that it would crack on being handled. So obviously low temps with the trailer static present no worry.
Then comes the question of what temperature risks doing damage if the trailer is towed. A quick Google search suggests that most rubbers have operating ranges down to -50 degF.
Maybe this is a question to ask one of the axle manufacturers?
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby cracker39 » Sun Mar 19, 2006 2:13 pm
At -50F, I don't believe I'd be doing anything that required rubbers!!!
Dale
cracker39
Images: 233
