I appreciate you help so much:
I will admit I didn't check the bearings because it was towing so well. My mileage was better coming home than going. My brother said he greased them for me and I should have checked.
The weight is an unknown. It is 6'4" x 8'6" and has a 2x4 (4 across and 4, 2x4x3' (wheel wells) frame with a layer of 2x6 over and 2x6 around. The axle is 38" from the rear and the springs are on top of the axle. More than half of the weight is on the front. I can't pick it off the ground and I pick up my 80 pound dog.
The tires can't touch anything but road, unless bounced and my not know it, I guessssssss.
I measured close from axle to tongue and doesn't look off. Can't get a within 1/4 inch. without help.
Didn't check to see if pidgeon toed. Not real sure I remember how to measure toe in or out, but it looks good.
Oh yeah. Tow vehicle has 14 inch tires. Tires on trailer are rated at 160 mph.
