skacutter wrote: I hear lots of folks comment that airbags are an expense. I keep finding 2 bag systems on the web rated for this load for about $200 bucks. New leaf springs are $51.99 a side.
Kevin A wrote:Boodro wrote:Ska, maybe you can add a couple of shocks mounted to the frame & axle ? If the springs are a little weak , shocks should help. Shocks are probably cheaper than new springs. Just a thoiught. Good luck!
Shocks are generally used to dampen the motion of the suspension. They won't do much for ride height or suspending the load of the trailer unless you use air shocks. If the springs are weak, they need to be replaced.
Users browsing this forum: No registered users and 30 guests
