CAD file for HF trailer?
Want to design your own teardrop or tiny travel trailer. You can do that in 2D or 3D. We keep our secrets in here!
Postby sheila » Mon Jun 29, 2009 4:00 pm
Does anyone have a model of the 5' wide HF trailer that they would be willing to share? I'm using SpaceClaim, but I can import quite a few different formats. 3D would be nice, but 2D would also work.
sheila
Postby absolutsnwbrdr » Fri Jan 29, 2010 4:52 pm
I'm also looking for HF trailer CAD model, but in the 4x8 version... anyone?
Zach
absolutsnwbrdr
Images: 411
Postby mikeschn » Fri Jan 29, 2010 5:24 pm
I have the 4x8... and you can probably just stretch it to get to the 5x8.
Let me eat dinner first... I'll be back in a bit...
Images: 479
Postby absolutsnwbrdr » Fri Jan 29, 2010 5:49 pm
Thanks Mike!
(but I forgot to mention that I was looking for an AutoCAD format... hope thats not a problem!)
Zach
absolutsnwbrdr
Images: 411
Postby mikeschn » Fri Jan 29, 2010 5:56 pm
Autocad can read a number of different formats, including SAT and Step.
Images: 479
Postby mikeschn » Fri Jan 29, 2010 7:29 pm
Tell me if you can read this...
http://www.mikenchell.com/images/4x8hf.stp
Images: 479
Postby absolutsnwbrdr » Fri Jan 29, 2010 8:25 pm
hmm... im runnin AutoCAD 2010 and it doesnt read that filetype
Zach
absolutsnwbrdr
Images: 411
Postby mikeschn » Fri Jan 29, 2010 8:40 pm
that's really strange... it should...
okay here's the sat version... if you can't read that then Autocad is in the dark ages...
http://www.mikenchell.com/images/4x8hf.sat
Images: 479
Postby chorizon » Fri Jan 29, 2010 9:48 pm
mikeschn wrote:that's really strange... it should...
I clicked on the link for the .stp and my machine wanted to open a text file. I saved the file, renamed it with a .stp file extension, and then opened it in Solidworks. It opened with a perfect assembly file with (67) separate part files attached. Very nice!
That's the cleanest file conversion I've made in a while! Thanks for the info...for future use of course! :thumbsup:
chorizon
Images: 94
Postby mikeschn » Sat Jan 30, 2010 5:22 am
Joshua,
We only do clean files here! ;)
:lol: :lol: :lol:
Images: 479
Postby absolutsnwbrdr » Sat Jan 30, 2010 9:55 am
Darn AutoCAD!! It would at least let me try to open that last file, but then said invalid file contents.
I guess I can draw up a sketch for my model if someone could give me a couple quick numbers... I just need deck height and distance wheel is from back of the trailer.
Zach
absolutsnwbrdr
Images: 411
Postby mikeschn » Sat Jan 30, 2010 10:05 am
I just exported it out as an Autocad 2007/2008 file. Give that a try...
http://www.mikenchell.com/images/4x8hf.dwg
P.S. You'll probably want to move the wheel rearward. The default location isn't good.
Images: 479
Postby absolutsnwbrdr » Wed Feb 03, 2010 10:50 am
Awesome work Mike! Thanks!
Zach
absolutsnwbrdr
Images: 411
Re: CAD file for HF trailer?
Postby toypusher » Tue Feb 14, 2012 7:25 pm
Thanks
toypusher
Images: 324
Return to CAD secrets
