SketchUp8 - How to change model in Inches to Millimetres
Want to design your own teardrop or tiny travel trailer. You can do that in 2D or 3D. We keep our secrets in here!
Postby donnan » Thu May 16, 2013 1:13 am
Hi guys,
I have google Sketch up 8 and have set in the preferences to use metric measurements.
When I open the CAD model of 2 Person Standby it's measurements have been done in feet and inches.
I went into Window/Preferences/templates and I can see my settings for Metric still stand yet in the model it only shows in inches.
Does anyone know how I can get these measurements to show in metric instead of the imperial measurements they were first done in?
Perhaps I have to manually work out and change all of these measurements to metric?
Life is too short not to enjoy it :)
When I gamble I like to win.
http://www.realpayers.com
donnan
Re: SketchUp8 - How to change model in Inches to Millimetres
Postby danlott » Thu May 16, 2013 10:59 am
Here is the file with millimetre measurements. Hope this helps.
2 person standy metric.skp
(1.25 MiB) Downloaded 232 times
The correct path to change dimensions is:
Window -> Model Info -> Units
Then select Decimal as the Format type. Then select the the unit of measurement that you want to use.
Dan
Hoplite Traveler Build thread
danlott
Images: 262
Postby donnan » Fri May 17, 2013 1:00 am
Thank you so much Dan, you saved me a heap of time in having to convert the measurements manually. :thumbsup: :beer:
Cheers
Paul
donnan
Return to CAD secrets
