Lil Diner stuff
Important Information and Stickies...
(Threads with essential information about building teardrops)
Re: EPS v Polyureathane
Postby mikeschn » Mon Dec 13, 2004 7:41 pm
Guy wrote:Dear Steve and Mike,
Is there any specific reason you chose EPS (polystyrene) over Polyureathane foam for the insulation?
If you mean this stuff... http://www.sprayfoam.org/
I don't have the equipment to spray foam in. EPS is cheap, effective, and available just down the road from me! 8)
Images: 479
Postby Steve Frederick » Mon Dec 13, 2004 8:13 pm
If you mean foil-faced urethane foamboard, Glue won't stick well to the foil face..That's why I don't use it! Besides, Mike brought a load of EPS out with the frame! :)
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
EPS v Polyureathane
Postby Guy » Mon Dec 13, 2004 8:21 pm
Dear Mike,
Sorry Mike. I did not mean spraying yourself. I meant rigid sheets like these http://www.lowes.com/lkn?action=frameSe ... /tuffr.htm
They are widely available. Please do not buy them from DOW since I am an Agent Orange person and would not be promoting Dow Chem.
Poly ure or Polyiso are basically the same. They have almost double the effective R VALUE of styrene and hold up better over the years. I do know they are more expensive , although I do not know how much so.
I was just wondering. If weight is one of the overiding quests, then a 1/2" frame with rigid urethane would be 1/3 lighter, just as structurally sound, and more insulating than 3/4" EPS.
A great site comparing the two for builders and architects www.thermocore.com.
Regards,
Guy
Guy
Images: 44
Postby mexican tear » Mon Dec 13, 2004 10:41 pm
Those Unimogs would look better with a teardrop behind them.
:lol:
kai
"Essie" and the Mexican Tear
mexican tear
Images: 14
Great update of Lil Diner Build Journal
Postby Guy » Wed Dec 15, 2004 5:16 pm
Dear Steve F,
Thanx for updating the Build Journal. Nice move on the ribs.
Steve, you seemed to have switched to the Roto-zip from the router. Any reason? How are the Roto-zips?
Regards,
Guy
Guy
Images: 44
Re: Great update of Lil Diner Build Journal
Postby Steve Frederick » Wed Dec 15, 2004 5:49 pm
Guy wrote:Dear Steve F,
I'm using the roto-zip bit only, in an adapter for the router. The bit produces a kerf of 1/8", just right for the headliner plywood that I'll use! I made a starter pass with a regular 1/8" spiral bit, then followed with the roto bit in three shallow passes. The zip-bits work great, just go shallow and slowly.
In practice, the off cut piece will be cut up to make the filler blocks that go between the roof spars. On the stripper, I made all those parts one at a time. Very tedious work! I think that this method will save a lot of work.
Glad you enjoy the website! Thanx!
Zip Bit Adapter
Cut out the headliner ledge
Cut the filler blocks...
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby OurStuff4You » Tue Dec 28, 2004 2:27 pm
All this is why I won't attempt building a teardrop .... you guys are amazing! :applause:
OurStuff4You
Postby Steve Frederick » Tue Dec 28, 2004 7:45 pm
I know someone who will build one for you!! :roll: ;)
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby mikeschn » Tue Dec 28, 2004 8:10 pm
OurStuff4You wrote:All this is why I won't attempt building a teardrop .... you guys are amazing! :applause:
Rhonda,
It's time to bite the bullet and have one built for you to match your little Metro. Are you ready?
Images: 479
Postby OurStuff4You » Wed Dec 29, 2004 5:31 pm
Getting close Mike. I thought for sure we'd be working on fixing up a trailer over this winter, but "our" trailer hasn't come along yet. However, when we've looked at the "pre-built" ones they've been out of our price range. While part of me wants to stay vintage, part of me would love one built to match the Met. Would be awesome cool.... :)
OurStuff4You
Postby mikeschn » Wed Dec 29, 2004 9:58 pm
OurStuff4You wrote:Getting close Mike. I thought for sure we'd be working on fixing up a trailer over this winter, but "our" trailer hasn't come along yet. However, when we've looked at the "pre-built" ones they've been out of our price range. While part of me wants to stay vintage, part of me would love one built to match the Met. Would be awesome cool.... :)
Rhonda,
email Steve Frederick... I'll bet you could work out something with him...
Images: 479
Postby OurStuff4You » Fri Dec 31, 2004 12:51 pm
Okay, sent out an email to Steve. Now I have to talk hubby into changing gears. :roll: This would also mean that I'd have to figure out exactly what I'd want in the tear ... and how to accomplish it! And yes Mike, that cutout you gave me is sitting right in front of my computer. I've been very quiet lately (lots going on) but still watch the boards and dream about my next trailer.....
OurStuff4You
Postby JunkMan » Fri Dec 31, 2004 6:05 pm
[quote]I'm using the roto-zip bit only, in an adapter for the router. The bit produces a kerf of 1/8", just right for the headliner plywood that I'll use! I made a starter pass with a regular 1/8" spiral bit, then followed with the roto bit in three shallow passes. The zip-bits work great, just go shallow and slowly.
[/quote]
Steve, those roto-zip bits sound good, can you go through 1 1/2" with them? I'm thinking of using 1 1/2" insulation on my walls, so would need 1 1/2" framing.
Also wondering how everyone cuts out their templates, do you freehand it? I was wondering If I could make a router guide that used string, with 2 fixed points, and wrapping around the router base somehow, kind of like the way it shows you how to draw ovals on angib's site.
And last, how do you keep Gorrilla Glue from foaming out and getting all over your finish? Could you put masking tape along the seam, and still be able to remove it after the glue set? Elmers is easy because you can see if it oozes out right away, then wipe it up with a damp rag, but the things I have used Gorilla glue on all had glue ooze out after a while.
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby Steve Frederick » Sat Jan 01, 2005 5:27 pm
Pryed myself out of the Lazyboy.. ;) I got a bit more done on the twins..
I got the windows cut into the doors. Mike has one door, I have two. We are using the same windows for the doors, so I cut them out together. I built-up the framing for the door panels too. Tommorrow, I'll get started on the wall insulation and pre-wire rough in.Image
Mike's Diner
My Twin Diner
A door, "clamped" to the bench to keep it flat while glue sets.
Last edited by Steve Frederick on Sat Jan 01, 2005 6:24 pm, edited 1 time in total.
Blessings, Steve
Building Journals
Steve Frederick
Images: 29
Postby mikeschn » Sat Jan 01, 2005 5:34 pm
That sure is looking sweet!
Are you going to hang the doors now too, or wait until it's installed on the trailer?
Images: 479
Return to Essential Information about building teardrops
