seamless aluminium
Important Information and Stickies...
(Threads with essential information about building teardrops)
seamless aluminium
Postby jlw » Mon Aug 11, 2014 6:19 pm
I am looking for a supplier of coiled aluminium in southern Ontario. I would like to have it at least 60 inches wide, as this will allow me to make one piece for each side and one piece for to roof.
I would also be ok with USA supplier that could ship to Lewiston NY. I have often popped over the river for online purchases.
thanks
jlw
Re: seamless aluminium
Postby George Taylor » Mon Aug 11, 2014 7:38 pm
Do you have a galley? The tear I built, I used 4'x10' sheets for the sides and was able to get 5'x12' and 5'x10 for the roof and galley. So no seam except where the hinge is for the galley and the corners of the walls and roof.
George Taylor
Postby jlw » Mon Aug 11, 2014 8:33 pm
I am planning 5 high and five wide. Tow vehicle is double cab Tacoma so I think the extra height will still be in the slipstream of the truck. I will have a rear galley
jlw
Postby George Taylor » Tue Aug 12, 2014 7:41 pm
Ok similar layout to mine. I know you can get 5ft by 10ft sheets as well as 5ft x 12ft ones. From your pic the 12 ft ones should make it, but you would need to measure it to be safe. I originally got mine from Yard Metals. But I have found a local roofer/sheet metal shop that I can get them from and they will cut them to what ever size I need.
George Taylor
Postby wyrdone » Fri Apr 10, 2015 7:38 am
Check to see if HarborSales.net will deliver to your area. They were where I got my skin from.
wyrdone
Return to Essential Information about building teardrops
