What kind of sticks would you build with?
Important Information and Stickies...
(Threads with essential information about building teardrops)
Re: What kind of sticks would you build with?
Postby fm-usa » Sat Jan 09, 2016 8:30 am
When I was (much) younger I worked at several different lumber yards.
Several times I've noticed when a new mfg of lumber is ordered from, the first several shipments are pristine and look like the pix above. After a while the usual grade (lower quality) filters in.
Back in the 70's a bundle of 1x6x12 ft cedar came in. As I was stocking it nearly every board looked cloned. The "Fire Grain" looked like it was photo'd onto every board also that "Fire Grain" had 5 distinctly different reds! On top of that every board was much lighter than the usual stock. Thinking on it now, I wonder if we got someone else's shipment, it was that odd.
Well, at that time I had no use for it but wondered if I should buy that stack for future use.
(40 years later) Now that I'm building up a Teardrop style trailer.... OH MAN, if only... :(
Is it possible, FULL RV in a 48 Sq.Ft. footprint & stay under 500Lbs wet?
SHE thinks teardrops are "cute" but I prefer a SKOSH mo-room & at 65+ the
body doesn't react/extract/move/mend/bend/lend or work like it use'ta.
NOW! Those unwanted guests moving in, Mr. 'Arther I. Tus' & Ms. DVT (grrr)
fm-usa
Location: ILLinois_60085 ================= Floyd_&_Debbie_+_Bailey
Postby Big Pavel » Wed Mar 02, 2016 11:04 am
All good day!
  I have two questions before you start to build a tear drop.
  1. What is the thickness of the plywood you normally use for the side walls.
  2. Have you tried to use heat-treated tree for sticks?
I work with a terrace board and now often build terraces of heat-treated wood. It is reliable, stable, very light tree.
Big Pavel
Postby fm-usa » Wed Mar 02, 2016 11:20 am
Big Pavel wrote:All good day!
heat-treated tree ???
Never heard that phrase before.
What is it?
Pix?
OH! You mean Kiln Dried?
fm-usa
Postby Big Pavel » Wed Mar 02, 2016 11:33 am
It's hard to say how it will be in English. Second name "thermomodified" tree.
Here is a Finnish company with which I work. Perhaps the description on their website will help you understand what I'm saying.
http://www.suomenlampopuu.com/en/slp-thermowood/#
Big Pavel
Postby fm-usa » Wed Mar 02, 2016 11:47 am
That process appears to be a different kind of Kiln Dried Wood.
It's very odd they use steam to dry out wood to 4%.
OK, I get it now. They're shortening the time to 'partly petrify' or an early stage of petrified wood.
Interesting but the wood will still be heavy.
fm-usa
Postby Big Pavel » Wed Mar 02, 2016 11:56 am
During the heat treatment of wood properties vary under the influence of high temperatures (about 160-215 ° C). During the heat treatment process the wood is heated to temperatures above auto-ignition temperatures, while protective gas is steam. Wood becomes durable to moisture, bark beetles and is not subject to torsion. My firm is engaged in construction of swimming pools and we use heat-treated decking around the pool. This is a very good choice.
Big Pavel
Postby fm-usa » Wed Mar 02, 2016 12:21 pm
Thanks, that was interesting.
fm-usa
Postby Big Pavel » Wed Mar 02, 2016 12:47 pm
Big Pavel wrote: 1. What is the thickness of the plywood you normally use for the side walls.
But the question remained unanswered. :)
Big Pavel
Postby tony.latham » Wed Mar 02, 2016 12:55 pm
I've used 3/4" and 1/2". I build with the Steve Fredrick's inside-out method (leaving a lip for the ceiling) and find the 1/2" surface is a bit thin for attaching to that area. You can remove more wood from 3/4" skeleton to meet the same weight as a skeleton made from 1/2".
Postby Big Pavel » Wed Mar 02, 2016 1:17 pm
Thank you!
Big Pavel
Postby pchast » Wed Mar 02, 2016 9:29 pm
It depends on their use.... of course.
:thinking:
I used:
Western red cedar, very light for the strength- rafters and door edge, window support.
(cut with a vertical grain, quarter sawn, and no run-out.)
Old Douglas Fir, very hard and 'not heavy'' - some of the blocking for attachments.
Oak, hard and heavy for hinge attachment to the doors.
:D
I likely used more wood, weight, than I needed in the foamy.
pchast
Images: 96
Postby fm-usa » Wed Mar 02, 2016 11:05 pm
pchast wrote:It depends on their use.... of course.
:thinking:
I used:
:D
AHHhhh, bet it feels solid.
fm-usa
Postby tony.latham » Thu Mar 03, 2016 12:51 pm
I've built sandwiched walls using 1x4" pine, 3/4" AC, and 1/2" AC for the skeleton.
I'll lay it right out on the carpet: Building a skeleton frame is much easier and quicker using plywood than "sticks". At least for me. :thumbsup:
Postby fm-usa » Thu Mar 03, 2016 2:31 pm
tony.latham wrote:I've built sandwiched walls using 1x4" pine, 3/4" AC, and 1/2" AC for the skeleton.
I'll lay it right out on the carpet: Building a skeleton frame is much easier and quicker using plywood than "sticks". At least for me. :thumbsup: Tony
Looks good. But I need as ultra light as possible... towing behind a GoldWing.
I wonder... 3/4 ply and router out the frame and leave 2 plys for the skin and fill with spray-foam? Interior skin will be PMF. LOT of waste for sure and probably several router bits. Even Carbide don't stand up well to glue joints.
I see your using TB and it has it's places. But on open surfaces, I'm a fan of 2 coats min. Sanding Sealer brush/roll.
fm-usa
Postby tony.latham » Fri Mar 04, 2016 11:38 am
I've been using PVA glues for 45 years and have yet to have a failure. What are you using sanding sealer for in a glue up?
And what size trailer are you building if you're pulling it from a goldwing?
Return to Essential Information about building teardrops
