Framing Assembly
Important Information and Stickies...
(Threads with essential information about building teardrops)
Framing Assembly
Postby Olman » Fri Feb 10, 2017 11:53 am
Anyone out there have any experience in using hardwood biscuits to join TD framing members? Appears to this inexperienced soul that this method of joining members would be lighter and more economical. Naturally, clamping in some instances, could present problems.
Olman
Re: Framing Assembly
Postby Thelgord » Thu Feb 23, 2017 9:43 am
I had to google this. I had never heard the term "wood biscuit" before, but I like the idea. I wonder if this could be used to "stretch" plywood?
Edit:
It appears it can: viewtopic.php?f=21&t=34381
Thelgord
Postby tony.latham » Thu Feb 23, 2017 1:06 pm
Olman wrote:Anyone out there have any experience in using hardwood biscuits to join TD framing members? Appears to this inexperienced soul that this method of joining members would be lighter and more economical. Naturally, clamping in some instances, could present problems.
On my first build, I used 1x4s for the internal frames and used biscuits for the joinery. (and some pilot screws)
Using boards for constructing this framework takes a lot of time. On my next two builds I used plywood and it's much quicker. As in days.
Postby Thelgord » Thu Feb 23, 2017 3:02 pm
So three layers of plywood all together?
Thelgord
Postby Woodbutcher » Thu Feb 23, 2017 7:20 pm
I use both biscuits and pocket screws for joining wood. Pocket screws are a better joint in most cases. Biscuits work best for edge gluing table tops, drawer fronts etc. Pocket screws give you a nice tight joint and help square up your work at the same time.
Woodbutcher
Postby tony.latham » Thu Feb 23, 2017 7:43 pm
Thelgord wrote:So three layers of plywood all together?
Short answer is yes. I use 1/4" underlayment which I find cheaper and higher quality than ACX. On the little 4-wide I built I used 1/8" Baltic birch on the interior.
I highly recommend Steve Fredrick's Teardrop Shop Manual: http://www.campingclassics.com/shopman05.html He goes into sandwiched walls in detail (plus a heck of a lot more) There's a review here somewhere.
Postby Thelgord » Thu Feb 23, 2017 9:28 pm
Thanks!
Thelgord
Return to Essential Information about building teardrops
