an online trailer weight and balance calculator
Important Information and Stickies...
(Threads with essential information about building teardrops)
Postby Bob Hammond » Wed May 03, 2017 5:29 pm
Curator
Museum of Unfinished Projects
Bob Hammond
Re: an online trailer weight and balance calculator
Postby mikeschn » Wed May 03, 2017 5:34 pm
That's angib's work. I use a simplified version of that, one of his eariler spreadsheets.
Here's what we've found of his page: http://tnttt.com/Design_Library/Trailer ... %20101.htm
Images: 479
Postby Apache Eagle Camper » Sat Sep 23, 2017 10:18 am
I have made a simple spreadsheet for roughly calculating balance fore & aft. It does not calculate side to side, just gives totals affecting tongue, axle, & gross weight. It is based on moment of axle in inch pounds of force. Requires inches for measurement and US pounds for weight. Measurements must be input as positive forward of axle & negative aft of axle. These already have data input as examples & can be cleared. I am building a Cargo Camper, these are some of my numbers. The sheets are protected, to prevent formula loss. They can be unprotected for modification if errors are found.
Trailer Weight Distribution Calculator.ods
Created in LibreOffice Calc saved as native ODS
(18.99 KiB) Downloaded 351 times
Trailer Weight Distribution Calculator.xls
Created in LibreOffice calc saved as XLS
(27.5 KiB) Downloaded 378 times
Damn the Guad's dry, my arms are so tired of paddling that I can't lift my ice chest lid..............
Apache Eagle Camper
Images: 56
Return to Essential Information about building teardrops
