CBO wrote:Why not 3/4 plywood with a thin carpet material glued on the interior walls? Wouldn't that be enough to ward off condensation?
Ottsville wrote:CBO wrote:Why not 3/4 plywood with a thin carpet material glued on the interior walls? Wouldn't that be enough to ward off condensation?
I like carpet; it's a simple solution to provide a minimum of insulation and a good bit of sound deadening. However moisture is still gets in the air, and most likely you just won't see it on the walls as the carpet will hold and disperse it. I would think that long term, this would eventually lead to moisture related issues in the wood and carpet.
tmoenter wrote:I made very lightweight walls using bubble insulation and dacron skins.
What is the weight difference between using 3/4" ply Skeleton vs. 2x2 framing with 1/8" ply?
Return to Essential Information about building teardrops
Users browsing this forum: No registered users and 24 guests
