Wall / sides construction
Important Information and Stickies...
(Threads with essential information about building teardrops)
Re: Wall / sides construction
Postby CBO » Mon Mar 19, 2018 1:34 pm
Why not 3/4 plywood with a thin carpet material glued on the interior walls? Wouldn't that be enough to ward off condensation?
CBO
Postby greygoos » Mon Mar 19, 2018 3:28 pm
Taking the lead from a builder on here who has completed more than 150 teardrops I used 1/2 ply on my last build and covered the interior with carpeting. I didnt have the camper for long, but never had any condensation problems. I guess it is your own preference and the climate you live in.
greygoos
Postby Ottsville » Tue May 08, 2018 7:44 am
CBO wrote:Why not 3/4 plywood with a thin carpet material glued on the interior walls? Wouldn't that be enough to ward off condensation?
I like carpet; it's a simple solution to provide a minimum of insulation and a good bit of sound deadening. However moisture is still gets in the air, and most likely you just won't see it on the walls as the carpet will hold and disperse it. I would think that long term, this would eventually lead to moisture related issues in the wood and carpet.
Ottsville
Postby Andrew Herrick » Wed May 09, 2018 1:16 am
You've hit upon the key distinction. Carpet doesn't have much insulation value. It adds R 0.25 - 0.5 (assuming minimal or no padding). In an absolute sense, it's not much, but in a relative sense, it might decrease the heat transfer of a solid plywood wall by 20-50%, which is fairly significant.
However, carpet has so much surface area that any condensation short of a tropical rainforest gets captured in the fibers, where it dampens the carpet (just a bit) and waits for dryer weather to evaporate. Manufacturers (Scamp rat fur?) have been putting carpet on the walls for 30+ years with minimal mildew issues. Just use the right carpet :)
P.S. Not to discourage the use of bubble foil insulation, but don't accept the stated R-values as valid for conductive heat transfer (no air space). They aren't accurate at all.
A few of my builds:
SEE MORE AT: boondockcampers.com
Andrew Herrick
Images: 15
Postby Ottsville » Wed May 09, 2018 6:10 am
Totally agree with you Andrew about using the right carpet. I have a piece of indoor/outdoor carpet(from home depot) on my shaded back porch in a high humidity area and no mildew issues in 10+ years. My concern would be putting carpet on bare or unsealed wood where the moisture captured in the carpet would pull through into the wood causing issues with the wood over time. Probably not an issue for those that live in desert areas, but for those in more humid/wet areas I would think that would be a problem long term.
Ottsville
Return to Essential Information about building teardrops
