I'm looking to build an 8x4 offroader and want some ideas on chassis strength. Best size steel, type of frame construction etc, etc, etc.
Cheers
Paul
Moderator: Sonetpro
mikeschn wrote:Paul,
I know Andrew will chip in... he's got a lot of prior thought into the chassis.
I know when I tried to compare steel to aluminum, I came away with steel being the winner.
What you really want to know is what the modulus of elasticity is for the various shapes you are talking about. You want the highest modulus of elasticity with the lightest weight. I'll bet a web search would get you started...
Dave Nathanson wrote:Hey, jagular7, that looks like a good sturdy chassis to start with. I do like the idea of the parking brake too. Really amazing that it such a rare feature!!! I've managed to get by with wheel chocks, but sometimes I wish I had a parking brake.
As an offroader, I feel that electric brakes are important too. Imagine this:
You're towing your trailer offroad, heading down a very long & steep hill. You are facing downhill, but not exactly straight downhill. You suddenly need to stop, and you hit the brakes. If the trailer doesn't help stop, it's going to apply all it's forces at an angle to the rear of your Jeep. This could turn your Jeep, pushing it a bit sideways. And that may not be desirable atall.
Dave Nathanson wrote:I also understand that there is probably no (reasonable) way to fit both a parking brake and electric service brakes into the same axle
