Suspension lift?
Moderator: Sonetpro
Suspension lift?
Postby kai38 » Fri May 21, 2010 11:16 pm
I have torsion axles on my teardrop I would like to get some lift on the trailer.
I think a body lift is not a good idea because the body is only mounted at 4 points on 2x2 tabs off the frame.
Any lift ideas are welcome
Thanks, Kirk
kai38
Postby deepvee » Sat May 22, 2010 7:56 am
Hi KIRK, Get a lower truck it will make your trailer look taller. :lol: With a body lift the trailer frame will still be at the same height. You should have some brackets made to move the axles lower. That would bring everything up. Nice looking setup you have :thumbsup: .
Lester
deepvee
Postby angib » Sat May 22, 2010 8:44 am
The simplest thing would be to take the trailer to a welder, have him cut the welds holding the existing axle to the frame (unless it's bolted), add some short lengths of 2"x2", 3"x2" or even 4"x2" square/rectangular tube as spacers and then bolt or weld the axle back in place under the spacers.
Obviously you'll need a plan for how to move or replace the fenders as they will look bad if left where they are.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby Shadow Catcher » Sat May 22, 2010 8:20 pm
I am working on an air shock addition to the Dexter axle and waiting for our new MM to work on adapting to the axle with brakes. There are pictures in the album showing the adapters.
One of the reasons was that I wanted the low profile for towing down the road but to be able to give a boost in height when I want it off road. And one of the other reasons is that since they can be adjusted independently they can level the trailer. If this works out we will offer it as a kit.
Last edited by Shadow Catcher on Sun May 23, 2010 5:13 am, edited 1 time in total.
Postby StormRider » Sun May 23, 2010 12:09 am
Bigger tires would be an option, depending on how much you want to go up. You've got 5 bolt wheels, and it's likely a 5x4.5 bolt pattern. depending on the backspacing required to clear the side of the trailer, you might be able to find very cheap 32"+ wheels and tires in your local classifieds.
If blocking the Torsion axles (easy and pretty cheap way to add 2"-4" lift) doesn't work, you could also consider a leaf spring/solid axle swap if your trailer frame is at the outside perimeter of the trailer. (I can't tell from your pic). Standard trailer leafs in a spring under setup would likely add several inches to your ground clearance, and setting them up spring over would add 4" to that. You could also use light duty vehicle leaf springs (i.e. Jeep CJ front springs) for a smoother ride and more lift options.
<img src="http://hphotos-snc3.fbcdn.net/hs358.snc3/29513_1365097661413_1650789676_863167_8282475_n.jpg"/>
Build Journal
StormRider
Postby deepmud » Sun May 23, 2010 12:49 am
My car-hauler used to be a camper trailer - it has two torsion axles - and in stock configuration, they bolted a 2x4" C-channel to the regular frame, that dropped the torsion units 4" lower - it's "blocking", like Stormrider said - you could do the same. How much lift do you need?
Also - adding shocks will be my next mod - after Shadow Catcher proves it out for me, lol 8)
deepmud
Postby kai38 » Thu May 27, 2010 11:02 pm
I would like to get at least 2 or 3 inch lift.
kai38
