I figure this is probably the best place to start posting.
I've been tent camping for the last 2 years or so, going into my third winter now. I started with an Ocala 5 (coleman) tent, but that got stolen at the end of the first year and I picked up a bigger tent. The Ocala was a 9x12(interior) with a large and small vestibule at each 12' end. I used aluminum laminated bubblewrap to insulate it durring the winter as I needed something flexible.
The new tent is a 17x10 so I'm able to have a bigger heater, I use a mr heater that mounts on a 5gal propane tank. I end up having to refill the tank about once every 2 or 3 weeks, depending on the temperature. I have camped in sub zero temperatures using the tents for the last 2 years, I pretty much live at Tuttle Creek State Park here in Kansas.
My primary concerns with the tent camping is having to move every 14 days, which is a real pain with the amount of stuff I have in the tent. But that's only durring the summer. The other concern is that some tree is going to fall on me while I sleep. In the last 2 years I have witnessed 1 entire tree, and 2 limbs big enough to destroy my car fall. I figure on building my own teardrop sometime in the next year or so, I know that some of the limbs that fall will still be able to wipe it out(even with a steel frame) if I build it light enough that my honda accord will be able to tow it.
I've been looking here for plans, ideas and resouces to help me in deciding what it is I want to build. Building a traditional teardrop (rounded) while not looking all that difficult seems like it may end up taking longer, and if I build a second I may end up going that route, at the same time I like the way they look. I'm leaning toward the weekender, as it seems like it will be simple to build, I also have ideas that may help it some with the weight. I hope to use cutouts like the weekender improvements use, but I wish to do so with almost all of the panels of the weekender. By skinning them with luan, or some other veneer I will be able to produce torsion boxes of all the walls and most of the panels, and I think 1/2' plywood would end up working well for the frame.
Cost is going to be a major issue for me, and so I hope to build it without a trailer, but using the same general plans of the ultralight. I think a straight tounge with a piece of angle iron at the back end where the tongue meets the center of the floor should work out well or I may end up using the ideas that were used on the other wooden trailer tear which was 5x8 floor plywood with 1x3s forming half of a torsion box. Then simply bolting the spring hangers directly to the wood, or possibly some small pieces of angle iron to spread out some of the stress a bit.
I would also like to have the back hatch open enough to be able to stand in the back, with a walkthrough galley. I would like to attatch to the back of the galley a canvas tent, which I hope to make out of either muslin, which comes 10' wide, or possibly duck cloth, depending on whether or not I will be able to adequately waterproof the muslin. I am looking for cheap solutions for waterproofing the outer skin of the trailer, and am not sure what material I will end up using. I have heard luan used quite a bit, aluminum sheeting (probably a bit expensive for me) as well as vinyl sheeting as used in bathrooms. I'm leaning toward the vinyl as it seems it would already be waterproof, but I've not looked to the cost of that yet. I've also seen various epoxies and paints used, but have to wonder if something like thompson's water seal would be sufficient. It will probably be one of the things I test while trying to waterproof the muslin, as well as some white roofing material which seems to dry something, like vinyl or tar.
Anyhow, been watching for about a month and reading though some of the threads looking at the ingenuity of the folks here and have a few ideas concerning popups, and such that I'd like to eventually share with you all. Don't know if you've seen the popup crates that staples has, but that was one idea that I thought might work for popups/drop floors. The end sides fold down and in, and the longer sides then fold like > < to alow the top to drop down. I've also seen some type of siccor mechanisms used in popups on vw microbusses, which look fairly easy to use, not sure about how easy it would be to build using that though. I've also seen pulley systems used, and they seem to be an easy way for setup, but they also seem to need a metal frame, and I would rather build in wood because of cost/ease of build.
Well folks that's about it for now. Just thought I'd say hi.
Martin
