Hello from Hagersville, Ontario, Can.
Postby Rickc » Sun Mar 16, 2008 11:53 am
I’ve been following the forum for a couple of weeks now and decided to jump in with both feet. Yesterday I bought my hitch for the car. I’m building the Cub or the Grumman for 2. I can get a 3500lb. axle and springs for $179.00. Would this cause me grief, with damage after the trailer is built because of the stiffness? Your opinions would be greatly appreciated.
Thanks, Rick
Rickc
Postby Miriam C. » Sun Mar 16, 2008 1:51 pm
Image to the playground Rick. Sounds like a good price however---it is over the top unless you are building real big..
You can remove springs to deal with the stiffness but why pull all that weight around.
Good luck and I bet the experts will be in here momentarily.
Now don't forget the :pictures: :pictures: :pictures: :designing: :question: :hammer: Gotta keep the bubble oil level.
Postby mikeschn » Sun Mar 16, 2008 2:59 pm
Hi Rick,
Welcome to the forum...
I believe the 3500# axle was discussed just recently. Let me see if I can find the thread...
Edit: there is a lot of discussion on 3500# axles, but this seems to be a good one...
http://tnttt.com/viewto ... xle#259499
Images: 479
Postby Hector » Sun Mar 16, 2008 3:35 pm
Welcome to the forum Rick! my wife is from London Ont. but I won't hold that against you.LOL
Hector
Images: 46
Postby doug hodder » Sun Mar 16, 2008 8:01 pm
Rick...you can get the 3500# axle and put whatever springs you want on it. I use that axle with a 4" drop on all of my tears. Spring it how you want. Doug
Postby Rickc » Mon Mar 17, 2008 10:00 pm
Thanks for the help. Ibought the 3500LB axle and springshope to start next weekend.
Thanks again. rick
Rickc
