New build in Ireland
Postby Peterireland » Wed Aug 07, 2019 3:24 am
Hi All,
Peter here in Ireland.
I am just about to commence my build of a tear drop.
Basic plywood build, that I am copying most ideas from similar ones that I have seen on line.
Things I am struggling with is getting some materials in Ireland.
Can anyone advise if there are places ideally in Ireland, or else in the UK, where I can get a suitable door, hurricane Hinge for the hatch etc.
I am very comfortable with woodwork, but not so much with metal work, so I was trying to avoid building my own door, as I am worried about getting a suitable seal on it, unless anyone has any god examples of how to do so, with fairly off the shelf materials.
There is no real market for the specialist stuff in Ireland, from what I can see, so I need to try to source standard materials for it all.
I can get some things from Ebay in the states, but delivery charges to Ireland are crazy, so ideally I will try to just source things in Ireland / UK.
Thanks guys
Peterireland
Re: New build in Ireland
Postby edgeau » Wed Aug 07, 2019 5:58 am
You can do a seal on your own plywood door. Here are a few shots of mine. I cut the jamb out of 4mm ply and stained it the darker colour. I expected to still need rubber but it turned out to work without. The latch is from the local hardware store ImageImageImageImage
Sent from my Pixel 3 using Tapatalk
edgeau
Postby Peterireland » Wed Aug 07, 2019 12:07 pm
Thanks Edgeau.
Certainly something to think about.
Cheers :beer:
Peterireland
Postby Peterireland » Wed Aug 07, 2019 12:14 pm
Any other options people have used for a hinge for the hatch.
Can't seem to find hurricane hinges in Ireland.
Are they known as any other name perhaps?
Peterireland
Postby tony.latham » Wed Aug 07, 2019 12:23 pm
Peterireland wrote:Any other options people have used for a hinge for the hatch.
There are several builders that have had luck using a piano hinge. It has to be covered with a rubber strip which is held down by aluminum strap screwed to both sides of the hinge.
Postby pchast » Wed Aug 07, 2019 9:14 pm
I used screen door hardware. Something like that should be available.
pchast
Images: 96
Postby TimC » Wed Aug 07, 2019 9:38 pm
Living hinge...
Sent you a PM about it.
Tim
Niagara, WI
My First Benroy Teardrop Build Thread - A 5x8 Woodie - viewtopic.php?f=50&t=63575
My Second Teardrop (partial) Build Thread - Started August '16 - viewtopic.php?f=50&t=66939
#3 My son's Benroy Foamie team build - Started July '20 - viewtopic.php?f=50&t=72877
TimC
Images: 629
