Hello
Hello
Postby TardisBuild » Mon May 22, 2023 11:40 am
We have acquired a 15 year old 5x10 squaredrop trailer that needs to be redone. Plan is to make it 5x12, with a galley, some internal storage for camping gear and fiberglass over 1/2" plywood, 2" insulation, then a nice 1/8" hickory interior. Current trailer is 1600# and hoping to get it down to 1300#. Teardown begins June 1 and hoping to have it capable by early October for the eclipse in Monument Valley.
171945
TardisBuild
Re: Hello
Postby tony.latham » Mon May 22, 2023 4:23 pm
3/4" of insulation in the walls and 2" in the roof is plenty.
Make sure the forward bulkhead is tall enough so you can sit up and not bump your head.
:thinking:
Re: Hello
Postby TardisBuild » Tue May 23, 2023 9:19 am
Thank you for the advice.
TardisBuild
Re: Hello
Postby Pmullen503 » Tue May 23, 2023 9:51 am
Depending on how you build your walls, 1/2" ply is overkill. Shaving 300# while making it 2' longer is going to require saving weight everywhere you can.
1/4" ply, 3/4 foam, 1/8" ply interior with minimal framing is plenty if you do a good job laminating the wall components together.
Pmullen503
Images: 67
