2 x 2 Framing Question
Postby phoenixbound » Fri Oct 20, 2017 3:22 pm
I see a lot of folks using 2 x 2 's for framing for counters and cabinets. Great idea, I like it. Just wondering about joints. It looks like everyone uses simple butt joints, but I am sure there is more to it than that. I would worry about the 2 x 2 splitting if I ran a screw in it. All help and especially pictures are appreciated.
Smart enough to know that I still have a lot to learn.
Build diary at viewtopic.php?f=42&t=69652
phoenixbound
Postby mcubberley » Fri Oct 20, 2017 3:27 pm
I used a Kregg jig and predrilled. I used this on 1x2 as well as 2x2 with wood glue on all joints. Half lap joints and even dados are all easy options depending on skill and resources and how good you are with measurements
Some day I will figure out something to put here. But for now....
_____________________________________________________________
I made my own image hosting, feel free to create a free account: http://shoppics.themodernshopteacher.com
I made my own blog, feel free to browse: http://themodernshopteacher.com
mcubberley
Re: 2 x 2 Framing Question
Postby jr9744 » Fri Oct 20, 2017 9:36 pm
phoenixbound wrote:I see a lot of folks using 2 x 2 's for framing for counters and cabinets. Great idea, I like it. Just wondering about joints. It looks like everyone uses simple butt joints, but I am sure there is more to it than that. I would worry about the 2 x 2 splitting if I ran a screw in it. All help and especially pictures are appreciated.
I'm using the Kregg system also. I'm no carpenter or framer, but from what I can tell it feels pretty solid. I'll be taking a trip soon with all the solar, water, electric, and framing in place and open to see how it performs. I'll be driving from MD to FL, so i'll see if what I did holds up and if I should make changes before I do the finishing stuff.
Good Luck.
7x7x16 V Nose Travel Trailer, First Build...In Progress
http://www.tnttt.com/viewtopic.php?f=42&t=68569
jr9744
Images: 311
Postby CoventryKid » Fri Oct 20, 2017 9:42 pm
Phoenixbound:
Hope the above pictures helps...when I secured the horizontal 2x2s to the vertical 2x2s, I simply drilled thru the vertical 2x2 into the horizontal one - no predrilling. However, at the other end where I had to toenail the horizontal 2x2 to the vertical one, I predrilled so I wouldn't split the wood.
So I hope I'm not simplifying it too much, but at a T joint, I did not predrill; at a toenail joint, I did.
After 2+ years and 30 some odd thousand miles (not kms), no failures.
As far as cabinets are concerned, I used 1/2 plywood and simple butt joints (never seen, so no esthetic value in doing anything fancier).
Hope this helps.
Doug
Vancouver Island, BC
GMC Savana Explorer Limited SE hightop conversion van
NEO NAVR 7x16 V-nose aluminum trailer now a comfortable travel trailer
Build: http://www.tusker-international.com/1-trlr-build.html
CoventryKid
Images: 130
Postby Spotman » Sat Oct 21, 2017 6:34 am
CoventryKid wrote:Image
Phoenixbound:
Hope this helps.
Sent from my SM-G920V using Tapatalk
2018 Heartland Terry Classic V21
2018 Toyota Tundra DC
Spotman
Images: 241
Postby phoenixbound » Sat Oct 21, 2017 12:30 pm
Very helpful. Thanks.
phoenixbound
Postby aggie79 » Sat Oct 21, 2017 2:32 pm
Kreg screws have drill tip that helps minimize splitting. Their screws come in coarse and fine threads. One is for softwood. The other is for hardwood. My brain is failing me at the moment but I believe the coarse is for softwoods like used for framing.
Postby aggie79 » Sun Oct 22, 2017 8:18 am
Thanks to Google, I have refreshed my memory. Coarse thread is for softwoods.
