10' x 8' Awning on a 6 x 12 V-Nose CTC
Postby phoenixbound » Tue Apr 17, 2018 7:12 am
Planning for an awning on my 6 x 12 V-Nose CTC. I am pretty sure I will be getting a 10' (length) x 8' (width) awning. Any pictures out the of this size of awning on my size of trailer? Just trying to see how it would line up. Also, does Aleko always quote the length first on their website? I am assuming that, but I have never ordered from them. Thank you.
Smart enough to know that I still have a lot to learn.
Build diary at viewtopic.php?f=42&t=69652
phoenixbound
Re: 10' x 8' Awning on a 6 x 12 V-Nose CTC
Postby Tommy B » Tue Apr 17, 2018 1:37 pm
my trailer is a 6x12 but not a v nose. This awning is 9 feet. A dometic 8500. just info. The trailer structure will determine just how long you can go. As you can see, 9 feet was the max for my trailer. Good luck.
Tommy B
Postby phoenixbound » Tue Apr 17, 2018 2:18 pm
Very helpful, thanks. I need to go measure again.
phoenixbound
Postby McDave » Wed Apr 18, 2018 12:02 pm
6 x 12 flat nose, 10 x 8 awning
148591
148590
148592
150374
McDave
McDave
Images: 412
Postby phoenixbound » Wed Apr 18, 2018 1:59 pm
Thanks McDave. At first I wondered why you mounted on a raised bracket, but now I see you had to clear the door. Nice.
phoenixbound
Postby McDave » Wed Apr 18, 2018 2:20 pm
Yeah, I probably over did that a bit, there is 6' of clearance at the closest point but I just wanted to get it mounted before the Ironhorse rally. Rev. B will be a lot cleaner and 4" lower and 1.5 "closer to wall. But It is functional and travels well as is.
McDave
McDave
Images: 412
Postby phoenixbound » Thu Apr 19, 2018 3:20 am
That is one of the cool things about doing a CTC. There are no set rules about how it can be customized. Whatever works for you, do it. BTW, I am guessing that I can use self tapping screws on the strip where the awning gets mounted. Looks like I will have to sacrifice a couple of clearance lights on that side. Even if I could leave them they are not going to be visible. Thanks again for all of the comments and pics.
phoenixbound
