Hader wrote:http://httpswww.tnttt.com/viewtopic.php?f=42&t=67319&start=105#p1207904
featherliteCT1 wrote:Do you think this is feasible? Or have I completely misunderstood what is possible?
Joel.brian wrote:Hader wrote:http://httpswww.tnttt.com/viewtopic.php?f=42&t=67319&start=105#p1207904
What Hader said.
Basically, you might want to consider building the a/c into a cabinet where you isolate the exhaust (hot air coming from the fins on the back of the unit) separate from the intake (the holes in the aluminum on the sides and top/bottom depending on unit). Then you vent the exhaust and allow the intake to suck in air and you have an a/c unit without cutting an aluminum frame stud.
Hader vented his in the floor and I’m in the process of doing mine in the v-nose with vents in the side and roof and using inline duct fans to push air in and pull exhaust out.
phoenixbound wrote:I am curious what the other side of this looks like when you get done and how well it works.Joel.brian wrote:Hader wrote:http://httpswww.tnttt.com/viewtopic.php?f=42&t=67319&start=105#p1207904
What Hader said.
flboy wrote:Very nice! How did you decide on isolating the intake and exhaust?
