hankaye wrote:flboy, Howdy;
Doubled up the wiring ?? Why, if you don't mind my asking. Understand the minimal loss aspect
but how much of a drop did ya have before doubling up?
Batteries look nice and neat under the seating how do you have them secured from bouncing
around or shifting?
hank
Hi Hank. I doubled up all the 4 Ga. battery wires (interconnects) and lines to the inverter and chassis. It is likely overkill.... but on the 6'ft run of 4ga wire going to the inverter (12ft round trip), I was losing just over a volt in the total circuit when running over 100A to the inverter. Half is dropped by the total resistance of the fuse, the multitude of connections on the batteries, the cutoff switch, ground lug on frame, etc., etc. etc. that are all part of the total circuit. Some of the loss was in the wire and it just reduced the total drop by .5 volts - .7 volts. I also put in a 400A busbar to consolidate the ground returns into the 500A Victron Monitor shunt. That may have had some effect as well with more surface area contact.
Believe it or not, that little bit (1/2 volt) makes a difference on the low voltage trip point for the inverter as the batteries start to drop. Not sure how much longer the inverter will run now before low voltage trips, but I have had the inverter alarm in the past when I ran the microwave in the morning and when batteries may have been at 75% - 70%. I am also thinking I may get a larger inverter someday to run the fridge and water heater at the same time when I am in a spot where solar is really good and I can expect recovery before sundown. The more current run, the more losses and the more the wire gage comes into play.
For battery tie downs.... well, I am lacking in that area quite honestly. I have them contained with 1*2's at the based where they do not contact a wall so they will not slide or move laterally. The trailer would have to flip on its side to get them to move. I have bounced the trailer down some roads as bad as I'd dare take it, and I have not had any issues with movement.
I have been thinking about that some as I like to have everything 100% secure and I know batteries moving around with cables (if the trailer flipped) could short out and cause a fire on top of the roll disaster. Some crank down straps and eyelets into the floor would work decent, I believe. I do not want to use metal as I hate to have wrenches or anything metal in the battery box with terminals exposed and in close quarters. I have almost burn things down before like that. Thoughts?
