Intro and title, “motobox that my wife would camp in”
Re: Intro and title, “motobox that my wife would camp in”
Postby hankaye » Sat Feb 01, 2020 8:00 am
BigDave_185, Howdy;
buytal tape, works fine ...lasts a long time.
Handling tip, if it's warm where/when you want to install the buytal tape
put it in the freezer for a while first, otherwise it gets to soft n saggy.
hank
hankaye
Postby BigDave_185 » Sat Feb 01, 2020 12:19 pm
How warm are you talking.? Outside air temp is about 35 today but the garage I keep at 65. Also need to sheet walls today before i get windows back in
BigDave_185
Postby hankaye » Sun Feb 02, 2020 11:50 am
BigDave_185, Howdy;
:lol: , Just another one of those warm winter days in Utah eh?
Throw it outdoors, bring it in when ready to apply it.
Generally if your comfortable in a T-shirt it can use some cooling down.
Just makes it easier to handle is all.
hank
hankaye
Postby BigDave_185 » Sun Feb 02, 2020 12:44 pm
Copy that
Any once have suggestions for transfer it the cut outer wall of the window to the sheeting I just put back up on the inside?
BigDave_185
Postby BigDave_185 » Sun Feb 02, 2020 8:23 pm
BigDave_185
Postby pchast » Sun Feb 02, 2020 8:59 pm
I think my approach would be to lightly attach the inner sheathing and
scribe it from the outside before window installation... :thinking:
pchast
Images: 97
Postby BigDave_185 » Sun Feb 02, 2020 10:05 pm
So I just re read my last post. Oh boy th at was bad!!!
So I took the vibe saw and cut it out. Then made my hole bigger
BigDave_185
Postby BigDave_185 » Sun Feb 02, 2020 10:08 pm
And he passenger side is re sheeted,
BigDave_185
Postby BigDave_185 » Sun Feb 09, 2020 9:39 am
Well folks I made a mistake, got another window in and managed to put a 3/4 screw into the frame and..... screwed through the window
But.... I might just tap it with the tig and see if I can close the holes up. Oops
BigDave_185
Postby featherliteCT1 » Sun Feb 09, 2020 12:34 pm
Or maybe just fill hole with caulk and hide with black touch up paint? :x
featherliteCT1
Postby McDave » Mon Feb 10, 2020 1:04 pm
Hey Big Dave,
S**t happens sometimes... a lot. No biggy. So I'm not sure of the camera angle there, but I think I see the drain slots at the top? IDK, but check that out. Drain at top would not be the preferred orientation. Slots made to let water out, not in. ;)
McDave
McDave
Images: 412
Postby dirtsailor2003 » Mon Feb 10, 2020 1:32 pm
Black caulk and call it good! As McDave said if those are the weep holes they need to go facing down or you’ll get water inside.
dirtsailor2003
Postby BigDave_185 » Mon Feb 10, 2020 9:52 pm
Well... testing out my old epoxy from a previous life
It’s old enough I had better check the chemical mix before I pour it on my trailer floor. Bottoms up as it goes. Hopefully in 12 hrs this cup is as hard as a rock.
BigDave_185
Postby BigDave_185 » Tue Feb 11, 2020 10:28 am
As of last night at 11pm. The cup was hot enough I couldn’t hold it, the rolled out sample was still wet.
Fast forward to today at 7:00 the cup was hard as a rock
BigDave_185
Now to locate some primer and I’ll have a self leveling epoxy that is bullet proof.
BigDave_185
