7'*18' V-Nose Cargo Trailer Toy Hauler Conversion
Re: 7'*18' V-Nose Cargo Trailer Toy Hauler Conversion
Postby McDave » Mon May 08, 2017 12:48 pm
Padilen wrote:Is that sound deadening an actual felt or like a foam? I have something that looks like that but it's foam. Was in a car topper tote I was given. I use it for padding. And don't laugh, but I've cut it and used it in my winter boots for insoles.
I made that mistake once, just once. You don't want anything in those boots that doesn't have the ability to wick the moisture out and away from the soles. Wool felt insoles and wool or wool/blend socks. NO COTTON or PLASTICS!! Learned that at -35f, Life got a lot better.... just sayin'..
McDave
McDave
Images: 412
Postby Padilen » Mon May 08, 2017 2:14 pm
These are the boots with the bootie. They had a cardboard piece that well it rotted. I wear wool blend socks and like them year around. But I only have a few thin pairs. The thick ones stretch out my shoes.
Padilen
Padilen
Postby flboy » Wed May 10, 2017 8:01 pm
I finally got motivated to build the last kitchen cabinet for the never finished CTC. I got the door for the pump cabinet done last weekend, so I decided I better do this before I loose motivation. This is a 18"W* 32"L * 12"D cabinet that takes up the dead space above the microwave. The kitchen was really missing a cabinet for plates, cups, and light things like that which are used often. The overhead cabinets are harder to reach and are not good for things you use often and the cabinet below the microwave is the pantry with heavier dry goods and etc.. I have to let the glue dry, finish the luan skin,build the face, put in two shelves and build the door to match the other cabinets. I should have it ready to hang by the weekend. We'll see. The cabinet will go to the ceiling, I just set the frame there to size it up.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby flboy » Thu May 11, 2017 8:56 pm
Got an hour or so in after dinner. I just need to fill screw holes with filler and final sand and paint on the cabinet, then I'll start the door. The last bit of woodworking I need to do on this CTC. :-)
Don (Flboy)
flboy
Images: 378
Postby flboy » Fri May 12, 2017 8:22 am
Fit check for the cabinet. Need to make sure on clearance for door swing and etc.. How do you like that... the paper towels are enough to hold it up.. It is very light, which is what I went for by framing it and using 1/8" luan covering.. That cabinet is going to add some very usable storage to the kitchen area and not really take up any area already in play. I also ordered a stove top cover which will allow the stove to be used for counter space when not in use.
These are all things I have decided to do after using it for a while. Will make it more functional.
Don (Flboy)
flboy
Images: 378
Postby Iconfabul8 » Fri May 12, 2017 1:52 pm
:thumbsup: :thumbsup: Very Nice
You could even hang the paper towels under there and save even more counter space.
Iconfabul8
Images: 14
Postby hankaye » Fri May 12, 2017 4:05 pm
flboy, Howdy;
Dang! Any more improvments and I wouldn't be suprised if "Better Homes & Gardens doesn't
come around beggin' to take some pix for the Summer issue...
:thumbsup: , :thumbsup: !
hank
hankaye
Postby McDave » Fri May 12, 2017 4:31 pm
Gotta love the color coordinated fire extinguisher. Tres Chic. ... 8) ...
McDave
McDave
Images: 412
Postby flboy » Fri May 12, 2017 10:46 pm
hankaye wrote:flboy, Howdy;
hank
Thanks Hank! :-)
Don (Flboy)
flboy
Images: 378
Postby flboy » Sat May 13, 2017 3:06 pm
Final finish is drying. I'll add hardware and hang it tomorrow. The cool thing about this small project is that I made this cabinet out of scraps left over from the build. I was saving them in my shed. The only thing I don't have are the hinges which I'll pick up at Home Depot on the way to take my wife to see "Beauty and the Beast". I wanted to see "Guardians of the Galaxy", but , gotta go do my time at the girly movies every now and then. :-)
Don (Flboy)
flboy
Images: 378
Postby mrwall1 » Sat May 13, 2017 4:32 pm
the cabinet turned out Sweet!!!
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Postby pchast » Sat May 13, 2017 8:03 pm
Nice! :thumbsup:
pchast
Images: 97
Postby m.colley » Sat May 13, 2017 10:17 pm
The cabinet looks good Don. You've got the cabinet making skills down to a science now. Not bad for someone that was gonna "buy" cabinets and doors, hahahaha
Martin
m.colley
Images: 83
Postby flboy » Sun May 14, 2017 3:37 pm
Thanks Martin (good to hear from you, I hope all is well).. Glad you gave me encouragement to try it myself. I like them with the flaws and all. It is amazing what is possible with some ordinary power tools and some persistence. Only could imagine if I had a real wood-shop with all the jigs and etc..
I mounted the cabinet today. I still have a piece of trim for the top to pick up and the rare earth magnet latch to install, but it is essentially done. No more cabinets to build... all done in that department. :thumbsup:
This cabinet has a lot of storage space. It should be able to take a little weight and some bouncing. We'll see.
Don (Flboy)
flboy
Images: 378
