Shadow Catcher wrote:I would be perfectly happy with a gas/DC/AC refrigerator if it came in a horizontal unit that does not spill all of its cold out when you open the door and on top of that I want it portable .
Shadow Catcher wrote:A eutectic system still uses a compressor but incorporates a tank filled with liquid that continually freezes and then defrosts. As the liquid freezes in the tank, its cooling energy is stored. This stored cooling ability is then released as the tank defrosts drawing heat from objects in the cool box. When the tank has almost defrosted the compressor starts again to freeze the liquids and repeat the process. This process is called a Eutectic phase.
Refrigeration systems are more efficient when heat rapidly saturates the evaporator, and as the eutectic evaporator is in a liquid it can rapidly absorb heat and lower temperatures. By comparison aluminum plate evaporators cooling the air run at much less efficient temperatures where the refrigeration systems coefficient factor is very low. (Put a hot can of drink in ice water and another on the shelf of a fridge at the same temperature. You will be drinking the one from the ice water ten times sooner!) So not only is the system operating in much more efficient conditions, it does the job so much quicker and with the eutectic hold-over, runs much less often. An aluminum evaporator plate system will typically cycle say 10 minutes on 20 minutes off. (Two cycles per hour or 48 cycles per day while the Eutectic system runs once per day or twice in hot conditions.)
Shadow Catcher wrote:One of the reasons I became interested in the eutetic system is the use by a couple of the Australian caravan makers and in the efficiency, power source for them is primarily solar.
I am aware of the marine applications, a number of which use water to cool the coils and even purpose built components are way expensive and I can buy a Whole Lot of ice. But then get a 12V Danfoss compressor for about 250$...
Shadow Catcher wrote:I would be perfectly happy with a gas/DC/AC refrigerator if it came in a horizontal unit that does not spill all of its cold out when you open the door and on top of that I want it portable.
Jeffmo63 wrote:Thanks all for the informative and sometimes entertaining posts. I should have made my intentions a little more clear. I visit the EAA up in Oshkosh every summer and camp out. As some of you may know there is no water and no electricity at the sites; just a really nice piece of grass and a small tree to mark each space. So while in years past I did the super cooler block ice thing, I was hoping to try something a little different (and as some of you noted, more complicated) this year. This year I will be without 115vac for upwards of 11 days so a refer/freezer with a low current draw is essential as will be 80+ watts of solar augmentation. I have picked the Norcold DE-490 stand alone to meet my requirements. Will keep you all posted on the install and operation.
