6x14-V Featherlite Horse Trailer Conversion
Re: 6x13-V Featherlite Horse Trailer Conversion
Postby Hiflyer » Sun May 27, 2012 2:06 am
roadinspector wrote:One suggestion on your battery placement. They need to be seperate from your interior. If they are inside, they really need to be in a sealed box that is vented to the outside. You don't want to expose the interior to battery gases.
t
They're Shuriken Absorbed Glass Matt Batteries - fully sealed units :)
http://www.shurikenonline.com/
AGM's only vent in extreme conditions from what I've read... Could still be wrong tho
Links to articles:
http://www.rvdoctor.com/2011/02/agm-bat ... rhome.html
Hiflyer
Postby roadinspector » Tue May 29, 2012 10:53 pm
Links to articles:
:thumbsup: Batteries have come a long way in a short period of time. I hope it works for you, sounds like an excellent product. I definitely am interested. Consider me paranoid, but I've seen batteries blow up and all kinds of strange things. Of course they were wet-cell type too. I will be researching the AGM more now. This is one of the main reason I read this forum, I've learned not to only fetch but I can roll over now! :beautiful:
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby Hiflyer » Tue May 29, 2012 11:55 pm
yeah, now I'm double thinking...
need to find out more & do more research! Safety is pretty important !
Hiflyer
Postby jwhite » Wed May 30, 2012 12:13 pm
I was going to buy the gel type batteries so I could charge them in the trailer and when I was talking to the guy at battery source that sells all type of batteries and mostly golf cart batteries he said that 2 golf cart batteries provided more amp hours than the gel type that they sell.
he also said that I could charge them in the trailer as long as the trailer was open and his words were as long as I wasn't hanging around in the closed trailer or sleeping in there while they were chargeing it would be fine.
I charge mine during the week before the weekend.
jwhite
Images: 46
Postby Hiflyer » Wed May 30, 2012 5:50 pm
that's good to know about the gel-types
I went AGM as I already had one, so a second to match was 'easier'
lots of plans a foot - just need time :D
Hiflyer
Postby Hiflyer » Thu May 31, 2012 11:22 pm
picked up two of these today
http://www.memoryexpress.com/Products/MX37359
200mm computer fans - pull .33amps @ 12v = 4 watts of power all out and push 150 CFM
quite quiet as well!
Sad tho when for $99 you can get a 5000 BTU air conditioner... But that pulls 400 watts...
Hiflyer
Postby Hiflyer » Mon Jun 04, 2012 12:05 am
OK just placed my last order for items for the trailer - LED's from http://oznium.com
These guys are beyond helpful! Absolutely top notch in my books :)
One week from now I should have everything & will get rocking!
So much planning, will be nice to be building already!
Hiflyer
Postby Hiflyer » Mon Jun 04, 2012 3:27 pm
ordered inside sheeting today - wife's choice ;)
picked up some unistrut as well
Hiflyer
Postby Hiflyer » Mon Jun 11, 2012 11:19 pm
Picked up all the gear today !
so far:
4x DUAL CIGARETTE LIGHTER SOCKET UNDER DASH MOUNT
Shuriken BT-120 Battery
Air Tabs
progressive dynamics convertor / charger + remote
LED lights from Oznium
blue sea 12 fuse
marinco inlets
Marinco Ends
marinco yellow covers
Xanrex 1000w Invertor + Remote
shuriken battery posts
Should start working on it right away as inaugural camp is only a couple weeks away!!
Hiflyer
Postby Hiflyer » Fri Jun 15, 2012 10:54 pm
what a week! finally had a couple hours tonight to get started
Day 5 - finished layout electrical in my mind & on paper & picked up last couple parts for that
Installed a temporary LED setup in the upper middle of the trailer as I'm not sure how bright they're going to be
16' total, double backed on itself to make 2 x 8' strips
Then finally decided how I want the electrical to be:
I'll run all electrical to the fuse box & have the 2 batteries, battery charger and inverter in it's own box.
Then have short cables to plug that box into the fuse panel when I go! No winter stuff to worry about...
It's gonna be a heavy box though as the batteries are ~80lbs each!
Went with some 5/8" plywood I had left over & a large number of brackets. all wood is glued together. That's the bottom you're looking at
One of the batteries is, um, helping that corner to stay put until the glue dries :)
I'll cut holes for handles & ventilation on the short sides
update as it's dark out finally!
Perfect amount of light I think - and they are on a dimmer, as will all the rest of the lights :)
Hiflyer
Postby Hiflyer » Fri Jul 13, 2012 1:41 am
OK, just completed a 3 week, 8100 kilometre trek and am super happy with how the trailer has come along :D
there is also a LOT to be said for sleeping in the same bed everynight!
Will post pix tomorrow
Hiflyer
Postby notoriouskelly » Fri Jul 13, 2012 7:35 am
Lookin pretty groovy, flyer! :thumbsup:
Is that just the LED's lit?
Cuz I like bright lighting and figured I'd need fluorescents.
If not, can you do a photo of how it looks with just the LED's on?
(and what's a kilometre?" ;)
2013 Continental Cargo 8.5 X 16 trailer Model ORRM816TA2
VETERANS: Get the benefits you deserve!
Free help at Hadit.com
notoriouskelly
Postby Hiflyer » Fri Jul 13, 2012 10:41 am
notoriouskelly wrote:Lookin pretty groovy, flyer! :thumbsup:
yeah, that's with the LED's lit in the back at night :)
It's 16' of the Oznium Waterproof LED's, in a neutral white. I really can't see anyoen needing anything more! They're usually dimmed by half at least for us
I'd probably go warm white if it were to do it again. with all the aluminum they appear slightly more blue than I'd like. Only slightly.
That may change when it gets sheeted though :)
Hiflyer
Postby Hiflyer » Sat Jul 21, 2012 10:01 pm
Day 6 - refit mattress frame to be lift-able
I had fixed the mattress hard in place with the unistrut for the last camping trip as I only had so much time
But now it's liftable! Lift the back door side 1/2 way up and secure. Then fully lift and lock the inside. Then finish the back door side the other 1/2.
When up, only covers about 2" of the windows leaving it cozy but super bright inside
That right there is why I bought this trailer - so it's pretty nice to see it finally starting to shape up!
https://picasaweb.google.com/1007827101 ... 1I2J5tegTg
Next to do:
3rd cross-member out of unistrut
Lights under the mattress
Wire back 12v sockets properly in place :)
Hiflyer
Postby 72FJ40 » Sat Jul 21, 2012 11:14 pm
Nice trailer and I really like your light install. Then I look at the last picture and see two Klipsch---nice
72FJ40
Users browsing this forum: Google [Bot] and 7 guests
