Window Air condition venting?
Re: Window Air condition venting?
Postby Socal Tom » Sat Apr 08, 2017 8:47 am
aggie79 wrote:I'm in the process of "hacking" a similar Frigidaire window unit to put into my teardrop. I plan on drilling a hole for condensate drain in the bottom of the unit. The condensate makes a pinging noise when it hits the fan and I didn't want that.
The water splashed on the coils improve the efficiency of the unit.
Socal Tom
Postby aggie79 » Sun Apr 09, 2017 7:21 am
I'm not worried about efficiency. My 1200 Btuh Petcool adequately cooled the teardrop. I'm more worried about the window unit being too efficient and not running the compressor long enough to remove humidity.
Postby McDave » Mon Apr 10, 2017 10:14 am
If you have water hitting the fan, or more likely, the fan hitting the water, you are removing LOTS of humidity. The final phase of the cycle is to remove the "condensed" heat from the condenser, and to properly lower gas and compressor temp.
just sayin',
McDave
McDave
Images: 412
