Third Trailer is the charm...
Re: Third Trailer is the charm...
Postby Shadow Catcher » Fri May 12, 2017 7:09 pm
Anything you can get a bolt cutter on is toast in seconds This is the one you can not.
92473
However one possibility is to use a GPS tracker hidden and powered by the trailer battery, The phone home when moved...
TRACKER TK103A http://vandogtraveller.com/cheap-gps-tracker-installation-and-review/
Postby DirtyD1833 » Fri May 12, 2017 8:46 pm
Picture is a little blury, looks like a beer can. What kind of lock is that?
DirtyD1833
Postby DirtyD1833 » Fri May 12, 2017 8:49 pm
https://www.linxup.com/
Looking at these guys, their monitoring is only $15 a month, and the unit has a 3 month battery life.
DirtyD1833
Postby DirtyD1833 » Sat May 13, 2017 4:27 pm
Had some child labor today....
DirtyD1833
Postby hankaye » Sun May 14, 2017 9:07 am
DirtyD1833, Howdy;
:applause: :applause: :applause: !!!
Good to see a 'kid' doin' "stuff" instead of nose down into a "devise".
Later in his life someone will nug another and say "he knows stuff". and
that will be a good thing.
:thumbsup: :thumbsup:
hank
hankaye
Postby Onetype » Mon May 15, 2017 7:48 pm
It's hard to steal a trailer with no wheels thats sitting on jack stands. Not as pleasant to the eyes as far as my neighbors are concerned but I could care less. I have that same lock over the ball of mine, with a big enough breaker bar that thing will break instantly since the yellow part of it is pretty much pot metal.
Onetype
Postby McDave » Tue May 16, 2017 7:27 am
I gotta get me one of those helpers. But yes, like Hank said, "Later in his life someone will nug another and say "he knows stuff". and that will be a good thing." You're doin' it right. ... ;) ...
Thanks for being a good parent, we need more of that.
McDave
McDave
Images: 412
Postby Rainier70 » Thu May 18, 2017 8:00 am
Here is what I use on my tire and axle: Pewag security chain and 60mm shackel guard pad lock. You need the larger triangle holes in your tire rim though.
Here is a YouTube on both of these.
https://www.youtube.com/watch?v=7S4gwYHZ6E8
Chain can be bought here: http://www.westechrigging.com/pewag-sec ... n-716.html The lock is available at many big box stores.
It is a seriously heavy chain. Cable, no matter how thick, can be cut with a pair of bolt cutters or even dike cutters. A strand or two at a time will do it fairly quickly.
Rainier70
Images: 244
