8.5 x 24 toy hauler...first build
Re: 8.5 x 24 toy hauler...first build
Postby colt45 » Thu May 25, 2017 9:25 pm
Progress this week has been somewhat slow, ( work gets in the way ). Got uppers in and countertops fitted along with the sink. Next is laminate and finish wiring.ImageImageImageImage
Sent from my SM-G930V using Tapatalk
colt45
Postby mrwall1 » Fri May 26, 2017 6:34 am
:thumbsup: Nice!!
my Old Teardrop build journal
viewtopic.php?f=50&t=59792
My New 7x16 Continental V Nose Build
viewtopic.php?f=42&t=67734
My Photobucket Link to 7x16 V nose build
http://s20.photobucket.com/user/mrwall/ ... %20Trailer
Mike
mrwall1
Postby jr9744 » Fri May 26, 2017 6:54 am
Looks great. Full size fridge, regular cabinets.....this is going to be a nice trailer.
7x7x16 V Nose Travel Trailer, First Build...In Progress
http://www.tnttt.com/viewtopic.php?f=42&t=68569
jr9744
Images: 311
Postby McDave » Sat May 27, 2017 1:13 am
Moving right along there. Lookin' good colt.
McDave
McDave
Images: 412
Postby Redneck Packrat » Sat May 27, 2017 7:33 am
Good looking setup, fast work putting it together! Looks like it's gonna be fun, which means it's gonna get used a lot :thumbsup:
Now....
colt45 wrote:I was going to go with a 20 footer but need to haul a side by side and 2 wheelers, add in the wide and 3 kids and 24' gets small fast. Glad i didnt go bigger tho.
I sure hope that was a typo, or you'll be in a pup tent gazing wistfully at the new mobile mansion! :lol:
Bill
Texas Gulf coast, near Corpus
Working on this, started 5/2017: http://www.tnttt.com/viewtopic.php?t=68614
Some days you're the bug, some days you're the windshield :?
Redneck Packrat
Postby colt45 » Sat May 27, 2017 9:50 am
Redneck Packrat wrote:Good looking setup, fast work putting it together! Looks like it's gonna be fun, which means it's gonna get used a lot
Now....
Haha typo but ive always liked sleeping undee the stars...
colt45
Postby colt45 » Sun May 28, 2017 10:20 pm
Got some more accomplished today, water test was succesful with no leaks, water heater worked great, outside shower worked great. Couter tops installed along with sink and rest of cabinet doors. Its coming along nicely. Next will be finish painting the rest of the trailer and install my flooring. Kitchen area will be vinyl plank and rear will either be rhino lined or just garage floor paint.ImageImageImageImage
colt45
Postby flboy » Mon May 29, 2017 12:03 am
Awesome job! You work quick!
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby rebar » Mon May 29, 2017 7:53 am
I'm single and I'm not much for crowded camp grounds so I'm looking for a 16' X 8.5' featherlite and put a 4" lift on it. I like colorado but not the crowds
Problem with 16' is most of them are only 7' or less wide with fendered wheels on the outside. Why anyone would want fendered trailer wheels? Cheaper to build I guess.
97 12 valve 4x4 5 speed
rebar
Postby flboy » Mon May 29, 2017 11:11 am
rebar wrote:Why anyone would want fendered trailer wheels? Cheaper to build I guess.
There are a few things I considered on the 7ft. wide vs. the 8 or 8.5 ft. wide.
1) Forward Wind Profile... Just less surface area to pull through the air. Not sure how much difference it makes overall since I don't have something to compare with, but every little bit adds up. I was trying to keep at least the sides in the truck's "air envelope" as much as possible. Aside from efficiency... it is huge for bug cleanup in Florida. :-)
2) Less width for branches and etc. to scratch down the sides. If my Mirrors clear it, typically the trailer will .
3) Rear Visibility when towing.. it helps.
4) I liked the looks better and with my intended floor plan design.. most of the extra width would have been aisle space (nice, but not necessary).. Less area, less to cool.
Those are my main reason's. I am sure the extra width would cost more.
Anyone know that, if you get the extra width, that the licensing (weight class) and etc. changes.. I have noticed that sometimes builders will put 1,900 lbs. weight on the sticker for various similar lengths... but I didn't see that on the wider versions? I found that odd as my original 14" CTC and this 18" CTC had the same weight on the sticker. And if you looked around, they were very careful not to get to 2,000 lbs. unless it was just obvious... is it just rounding of numbers or is there something a 2,000 lbs trailer weight triggers?
Don (Flboy)
flboy
Images: 378
Postby Padilen » Mon May 29, 2017 12:58 pm
As Don has said width and height more wind resistance. Fenders to not intrude inside, changing flats easier.
Custom order size and style you want. Why do a 4" lift when you can order with a straight axle & over or under slung.
My CTC is 7x12 toy hauler plenty of room for me and dog. But mines a camper not an RV.
Padilen
Postby rebar » Mon May 29, 2017 1:32 pm
Padilen wrote:As Don has said width and height more wind resistance. Fenders to not intrude inside, changing flats easier.
I understand some vehicles don't have extendable mirrors or the power to pull a 8' wide trailer, but I already have a tow vehicle capable of that. It pulled my old 24' featherlite toyhauler 4"lift with ease at 15 mpg. 75 mph 14000# gross
My thinking says if the outside wheel to wheel distance is around 8.5' .. Why build the trailer much narrower? Your already rolling over 8.5' of ground, might as well take advantage of that 8.5' I cant agree with your reasons Padilen. Who cares if the wheel wells intrude in when you just increased trailer width 1 1/2 feet? My wheel wells had fold up couch beds over them.
I never buy new, or I would have already bought another featherlite 4926 0016
rebar
Postby Padilen » Mon May 29, 2017 1:56 pm
Agree with my reasoning? I'm only saying what's been said. Narrow pulls easier with less wind resistance. And why have a 6-7 wide with wheel boxes intruding on space? Not everyone wants couches or boxes over them. Not everyone has max towing capacity. They make them different because we are different and have different needs. I called Dexter and American Hauler to ask why drop axles not straight. I was told that the majority of buyers want lower floors. The minority want ground clearance. So they produce what sells on dealer lots and custom build for the minority. Agree or disagree but not with me.
My thinking is you should buy what you want. And if it's not available used, buy new.
Padilen
Postby flboy » Mon May 29, 2017 2:14 pm
@rebar, You asked why would anybody want to. Those are some reasons folks may want to for their needs/desires. That is why there are 33 flavors at Bressler's Ice Cream. :-) Pick your favorite and enjoy.
Don (Flboy)
flboy
Images: 378
Postby McDave » Tue May 30, 2017 10:49 am
flboy wrote:Anyone know that, if you get the extra width, that the licensing (weight class) and etc. changes.. I have noticed that sometimes builders will put 1,900 lbs. weight on the sticker for various similar lengths... but I didn't see that on the wider versions? I found that odd as my original 14" CTC and this 18" CTC had the same weight on the sticker. And if you looked around, they were very careful not to get to 2,000 lbs. unless it was just obvious... is it just rounding of numbers or is there something a 2,000 lbs trailer weight triggers?
I'm thinking that is based on axle rating. Same axle for varied lengths = same weight on sticker?
McDave
McDave
Images: 412
