fourbtgait wrote:Typical, I cannot blame them. 17" wide, cut ply 16". Otherwise you waste money.
Probably put 1/4" birch beadboard over it.
Padilen wrote:RV doors are usually made with a foam core. Nothing to "open".
The barn doors if they are similar to my ramp, just remove the paneling/plywood. Not sure as I have a ramp. Bolts for hinges maybe through to interior?.
m.colley wrote:fourbtgait wrote:Typical, I cannot blame them. 17" wide, cut ply 16". Otherwise you waste money.
Thats why I stood mine up after insulating, I used pine lath strips at the small seam/gap left after rehanging. The lath also helped hide the screw heads at the seams.
Martin
fourbtgait wrote:Padilen wrote:RV doors are usually made with a foam core. Nothing to "open".
Thank you. The only reason to open the rv door was to insulate it if needed. I was thinking of putting a window in it which would need wood stiffners added, which possibly could be done without taking the skin fully off.
I am sure the ramp construcrion is same as barn doors. Yes, the hinge bolts go clear thru, looking at it as you said, I should be able to just take the inside wood skin off.
fourbtgait wrote:For those that have barn doors and open them to 90* from the trailer, not all the way open and tied back, not inline with the sides, but standing straight out from the sides.....
Do you have a method of holding them open securely thus? Looking at having a drop down counter on each door for use as needed.
rxberg wrote:fourbtgait wrote:For those that have barn doors and open them to 90* from the trailer, not all the way open and tied back, not inline with the sides, but standing straight out from the sides.....
I'm wondering the same thing. My plan at this point is to make a gate drop bolt out of rebar, but I'm definitely open to suggestion.
fourbtgait wrote:I am sure the ramp construcrion is same as barn doors. Yes, the hinge bolts go clear thru, looking at it as you said, I should be able to just take the inside wood skin off.
Padilen wrote:Here is what my " take out" looks like
m.colley wrote:fourbtgait wrote:I am sure the ramp construcrion is same as barn doors. Yes, the hinge bolts go clear thru, looking at it as you said, I should be able to just take the inside wood skin off.
My ramp door isn't built anything like any trailer barn doors or RV door I've ever seen. The exterior is skinned in aluminum like the rest of the trailer, the inner frame is built like my trailers side walls ( 1x 1 1/2 14g tubing) but stiffer ( more bracing ) then skinned with 3/4 plywood on the interior side. I pulled the 3/4 ply and insulated the ramp when I cut and braced it for my window ac install.
Martin
