Diesel Heaters
Re: Diesel Heaters
Postby troubleScottie » Mon Mar 18, 2019 2:03 pm
What about the proprane/butane heaters -- Propex HS2000 or HS2211 (external mountable) 2K heaters. A bit pricy. Thermostatically controlled, so cycles on it own. Less issues with the fouling due to the propane. Not a bad choice if you are already carrying propane. Have a burn rate on average 1lb. of propane for every three hours of use.
I recall the official manual has the attitude limits, but cannot locate it. Several people posted working at up to 10,000 feet.
Michael Krolewski
Scottish Terrier Fancier
troubleScottie
Images: 16
Re: Diesel Heaters
Postby tony.latham » Mon Mar 18, 2019 5:06 pm
troubleScottie wrote:What about the proprane/butane heaters -- Propex HS2000 or HS2211 (external mountable) 2K heaters. A bit pricy. Thermostatically controlled, so cycles on it own. Less issues with the fouling due to the propane. Not a bad choice if you are already carrying propane. Have a burn rate on average 1lb. of propane for every three hours of use.
Ask me this fall after I've got this in my new build:
Re: Diesel Heaters
Postby rebar » Thu Jul 25, 2019 12:45 pm
Chasein70 wrote: The Espar doesn't work well at all above 5,000'. Gets worse as the unit gets older. Espar sells a high altitude pump which pumps less fuel and lowers the BTU. Some Chinese units allow you to set the fuel flow which is SMART!! Then you can adjust with a pump change for the altitude. Mine would not work at all at 7,000 and just give up. Once again, every time it gives up you've built up a ton of crap in the combustion chamber
Thanks for that altitude information Chasein70, but you burst my bubble. I was wondering if anyone made diesel water heaters also and found this vid about a Espar diesel boiler that heats glycol which is pumped to anything you want to heat including your hot water and cabin heat..
https://www.youtube.com/watch?v=0OiDufshu_Y
But if its not designed for altitudes over 7000' I cant use it.
But I am reading they make a high altitude model and reports of people using them at 10,000'.
Pitkin Co, one of my favorite towns is at 9220′
https://sprinter-source.com/forum/showt ... hp?t=63606
But after reading all the hoops people jump through to run these in the mountains, Im leary. lol
97 12 valve 4x4 5 speed
rebar
Users browsing this forum: No registered users and 26 guests
